#216839 - 23/05/2004 07:27 jEmplode v54 + Hijack update problems
SonicSnoop
Loc: Triangle, VA
I am trying to update Hijack with jEmplode and am getting the following error:
You must have Hijack version 242 or higher, be connecting with jEmplode over Ethernet, and 'Use Hijack when Possible' enabled under Tools=>Options...to upgrade Hijack.
I have Hijack v838 installed on it right now, I am connected to it over ethernet: can telnet in, view web interface and sync with jemplode everything. Under tools and options I have that box checked. Its worked before at home but not at work. anyone have any ideas? Thanks
#216840 - 26/05/2004 12:39 Re: jEmplode v54 + Hijack update problems [Re: SonicSnoop]
SonicSnoop
Loc: Triangle, VA
Anyone have any ideas?
#216841 - 26/05/2004 12:54 Re: jEmplode v54 + Hijack update problems [Re: SonicSnoop]
mcomb
Loc: San Carlos, CA
JEmplode uses ftp to connect to the player to upgrade the kernel. See if you can connect to the player with your ftp client of choice. I believe there are some hijack options to disable or password protect ftp which you may have set (and possibly forgotten about).
-Mike
#216842 - 26/05/2004 23:09 Re: jEmplode v54 + Hijack update problems [Re: mcomb]
SonicSnoop
Loc: Triangle, VA
Ahhh! Thats it!,for work I disabled ftp.:) Forgot about that.Thank you!
#216843 - 03/06/2004 00:03 Re: jEmplode v54 + Hijack update problems [Re: SonicSnoop]
rowitech
Loc: Germany, Cologne
Oops, the same happened for me. Thought of a bug in jemplode that would be fixed one day. Updated manually then. Thanks for posting and replying :-).
Rolf
Connecting Empeg via Bluetooth or Wireless LAN http://empeg.rowi.net
*** Proud owner of the European Worst Install Trophy 2003 ! ***
RoWi
