#224467 - 24/01/2004 11:54 tRio on receiver hanging after 5 or 6 songs
lancelot
Running jrec 0.2.5 + trio 0.1.4.alpha5 on Linux. (Also, java 1.4.2_01)
No error messages from jetty or trio on initialization. Using jukebox mode, 5 or 6 songs play fine, then...
PlayerStream (/192.168.2.51) - Next get: 5562
*** Short JRec content read - setting EndOfTune. src_id: 6105, tuneOffset: 2561707, bufferOffset: 0, reqLength: 4800, readLength: 4105
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: Voices Carry
PlayerStream (/192.168.2.51) - Next get: 4800
*** Short JRec content read - setting EndOfTune. src_id: 8053, tuneOffset: 5277200, bufferOffset: 0, reqLength: 6000, readLength: 1608
java.lang.NullPointerException
at trio.player.TRioPlayerJukeboxSequencer.notifyCurrentTuneChanged(Unknown Source)
at trio.player.TRioPlayerJukeboxSequencer.getNextTune(Unknown Source)
at trio.player.TRioPlayerSequencedStream.getNextTune(Unknown Source)
at trio.player.TRioPlayerStreamImpl.processDataRequest(Unknown Source)
at trio.player.TRioPlayerStreamImpl.messageReceived(Unknown Source)
at trio.TRioUnit.notifyMessageListeners(Unknown Source)
at trio.TRioUnitControlThread.run(Unknown Source)
Got connect from /192.168.2.51
Receiver then hangs at the tRio flash screen. I am then forced to restart the tRio server and it re-connects and starts running again for a few more songs.
No wireless LAN, 10 Mbps hub.
#224468 - 24/01/2004 16:44 Re: tRio on receiver hanging after 5 or 6 songs [Re: lancelot]
pauln
Do you have any repeat or random modes set when this happens? And what tune would you have expected to hear after "Voices Carry"?
Paul
Paul (the tRio guy)
#224469 - 24/01/2004 18:28 Re: tRio on receiver hanging after 5 or 6 songs [Re: pauln]
lancelot
Yes, RANDOM was on when this particular log was captured (so I don't know what the next tune would have been) although I have the same happen when neither RANDOM nor REPEAT was on.
#224470 - 25/01/2004 10:56 Re: tRio on receiver hanging after 5 or 6 songs [Re: lancelot]
lancelot
Paul,
I'm gathering some more data on this problem. I'm going to grab a log with RANDOM off and also will try with only a few songs to see if that is affecting it in any way.
Bob
#224471 - 29/01/2004 10:56 Re: tRio on receiver hanging after 5 or 6 songs [Re: pauln]
lancelot
Paul -
Here's a log capturing the problem. One important (?) bit of info is that the song it hangs on (The Moon and St. Christopher) is the "last" one listed in the JReceiver database. I assume it should wrap around and play the first song in the database in Jukebox mode.
Thanks, Bob
STARTED tRio Wed Jan 28 18:59:34 CST 2004
Start of TRioServer. Version 0.1.4.alpha5
Defaulted http document root to: //root
Loading TRioPlayerLayout: universal
Loading TRioPlayerLayout: windows
ImageTranslation: byte-binary
RMI Registry created sucessfully on port 1099
binding rmi: rmi://127.0.0.1:1099/TRioServerRemote
binding rmi: rmi://localhost.localdomain:1099/TRioServerRemote
Creating sockets
Http server opening port 8090
Http server listening on port 8090
creating udp socket. local port: 19680, timeout: 15000
TRioUnitControlThread (/192.168.2.51): Starting
TRioUnitControlThread (/192.168.2.51): Waiting for Rio to accept connection. ip: /192.168.2.51, port: 19682
*** start of TRioPlayerJukeboxDlg
TRioUnitControlThread (/192.168.2.51): Rio has accepted connection. Interface: /192.168.2.60
PlayerStream (/192.168.2.51) - streamStart()
PlayerStream (/192.168.2.51) - sent Purge(). dataLen: 8000
PlayerStream (/192.168.2.51) - sent Play()
*** Short JRec content read - setting EndOfTune. src_id: 8731, tuneOffset: 4089927, bufferOffset: 0, reqLength: 5494, readLength: 4111
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: In Your Eyes
PlayerStream (/192.168.2.51) - Next get: 6000
*** Short JRec content read - setting EndOfTune. src_id: 8700, tuneOffset: 3212266, bufferOffset: 0, reqLength: 4800, readLength: 1968
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: Love At First Sight
*** Short JRec content read - setting EndOfTune. src_id: 8703, tuneOffset: 3830414, bufferOffset: 0, reqLength: 4206, readLength: 4071
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: Confide In Me
*** Short JRec content read - setting EndOfTune. src_id: 8699, tuneOffset: 5615044, bufferOffset: 0, reqLength: 4800, readLength: 2491
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: The Hard Way
*** Short JRec content read - setting EndOfTune. src_id: 8726, tuneOffset: 5260212, bufferOffset: 0, reqLength: 5494, readLength: 2545
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: He Thinks He'll Keep Her
*** Short JRec content read - setting EndOfTune. src_id: 8727, tuneOffset: 4880914, bufferOffset: 0, reqLength: 5494, readLength: 977
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: Rhythm of the Blues
PlayerStream (/192.168.2.51) - Next get: 4517
<< stuff deleted to save space, playing songs in sequence, no RANDOM, no REPEAT >>
*** Short JRec content read - setting EndOfTune. src_id: 8744, tuneOffset: 4018874, bufferOffset: 0, reqLength: 5494, readLength: 454
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: Halley Came to Jackson
PlayerStream (/192.168.2.51) - Next get: 5040
*** Short JRec content read - setting EndOfTune. src_id: 8745, tuneOffset: 3800490, bufferOffset: 0, reqLength: 5494, readLength: 4634
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: What You Didn't Say
*** Short JRec content read - setting EndOfTune. src_id: 8746, tuneOffset: 5541559, bufferOffset: 0, reqLength: 6000, readLength: 4365
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: You Win Again
*** Short JRec content read - setting EndOfTune. src_id: 8747, tuneOffset: 4805951, bufferOffset: 0, reqLength: 6000, readLength: 4365
PlayerStream (/192.168.2.51) - End Of Tune. nextTune: The Moon and St. Christopher
*** Short JRec content read - setting EndOfTune. src_id: 8748, tuneOffset: 5219731, bufferOffset: 0, reqLength: 6000, readLength: 2275
<tRio looking for server...>
