#235483 - 28/09/2004 16:46 Windows memory use question
Ezekiel
Loc: NH USA
In 2k & XP the Windows Task Manager has tow tabs showing how much memory is in use: the Processes and Performance tabs.
How come the number shown in PF Usage portion of the Performance tab is always greater than the sum of the Mem Usage column from the Processes tab? My Processes (at the moment) add up to about 510MB, and Performance lists 819-820 MB? I would think these two would tie out. What am I missing?
-Zeke
WWFSMD?
#235484 - 29/09/2004 01:00 Re: Windows memory use question [Re: Ezekiel]
Loc: Los Angeles, CA
mem usage by default = just physical. goto the process tab -> view -> select columns -> check virtual memory size -> ok. add those two together, and you have a winner.
#235485 - 29/09/2004 10:18 Re: Windows memory use question [Re: image]
Ezekiel
Loc: NH USA
Thank you so much. I never even knew those other options existed.
-Chris
WWFSMD?
