#23683 - 11/12/2000 18:40 Is anyone using Redhat 7.0 to compile
TomG
Has anyone tried to recompile the empeg kernel using redhat 7.0 and the cross-compiler ? I keep getting an error telling me to update my Binutils to version 2.9.5 and Redhat 7.0 installs with 2.10.0.18.
#23684 - 11/12/2000 19:50 Re: Is anyone using Redhat 7.0 to compile [Re: TomG]
borislav
Loc: Sunnyvale, CA, USA
The version of binutils that Redhat comes with doesn't matter - it isn't set up for cross-compilation, so you need a special one anyway. Grab a source tarball of binutils 2.9.5.0.22 (for example from the source rpm in Redhat 6.2) and compile it for an ARM target. I don't have the exact instructions for doing that but I remember it being fairly painless.
Borislav
#23685 - 12/12/2000 00:30 Re: Is anyone using Redhat 7.0 to compile [Re: borislav]
mcomb
Loc: San Carlos, CA
Good luck getting anything to compile with the version of GCC redhat 7 shipped with (2.96). My laptop with RedHat 7 on it (just switched to FreeBSD actually) wouldn't even compile the kernel sources shipped with RH 7 with the default GCC.
-Mike
#23686 - 12/12/2000 01:46 Re: Is anyone using Redhat 7.0 to compile [Re: mcomb]
borislav
They ship egcs-1.1.2 (as kgcc) for exactly that purpose.
Borislav
#23687 - 12/12/2000 12:25 Re: Is anyone using Redhat 7.0 to compile [Re: TomG]
bmihulka
Loc: Lincoln, NE
If you are using the cross-compiler from the developer site it has an old version of binutils that doesn't compile new kernels. I have a new package on my web page that I have used under Mandrake 7.0 and Debian Potato, it should run under Redhat 7.0. You can get it on my programing page.
Brian
-See my empeg here-
Brian
-See my empeg <a href="www.hulkster.net/empeg" target="_blank">here</a>-
#23688 - 13/12/2000 14:08 Re: Is anyone using Redhat 7.0 to compile [Re: bmihulka]
phaigh
Brian,
Any particular reason you don't want non-us people to download the toolchains?
I do want to, but If there is a legal implication, I'll hold off.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#23689 - 13/12/2000 14:14 Re: Is anyone using Redhat 7.0 to compile [Re: phaigh]
phaigh
OK, I'll read the webpage more carefully next time.
However, I thought that 'crypt' and other 128 bit encryption software was now okay to download, as long as you don't export to a US embargoed country - no?
Paul.
#23690 - 13/12/2000 14:49 Re: Is anyone using Redhat 7.0 to compile [Re: phaigh]
bmihulka
Loc: Lincoln, NE
I'm not certain on that. I just put it there because I know the Howto says something about exporting the source. I'm not watching my logs and I don't think anything would happen to me, I just put that up for a safety measure. Thats all I'm going to say now.
Brian
-See my empeg here-
Brian
