#237192 - 10/10/2004 23:16 jEmplode and song Position
woops
Hello,
Emplode imports songs such that position and track number were in order. If you pressed the down button 3 times and played randomly, then unsorted the playlist, it would unsort around the album the song was playing from (if you had your filenames right).
1)With soup playlists is position important in jEmplode? If so, how do you get songs to import such that, basically, position number corresponds to track number instead of what seems to be the default jEmplode way of position number is determined by alphabetical sort of titles.
2)How does autosort on import work? what 'fields' for tag name works? ie: fid, FID, {fid}, etc.? is there a field for filename?
Bottom line: Can you get a shuffled Down Button pressed 3 times to unsort around the album the playing song is from?
Thanks.
#237193 - 10/10/2004 23:51 Re: jEmplode and song Position [Re: woops]
mschrag
Loc: Richmond, VA
As far as sorting, jEmplode 69 adds per-soup-layer sorting, so you could create the bottom layer that would sort by track number.
#237194 - 11/10/2004 11:32 Re: jEmplode and song Position [Re: mschrag]
woops
MSCHRAG,
So song position is of no importance? Which soup layer is controlling when down button is pressed 3 times?
Also,
On large databses, can the timeout be extended for the retries after reboot?
On the occasions where something has happened and the synch has failed....is there a way to avoid having the empeg "rebuild music database" and let the computer do it instead?
#237195 - 11/10/2004 11:59 Re: jEmplode and song Position [Re: woops]
mschrag
Loc: Richmond, VA
If you're asking if position matters in soup playlists created by jEmplode, the answers is "sort of". It matters in that position should ultimately be equal to your sort order in a soup playlist. You definitely shouldn't change the order of tunes manually inside of a soup -- that's gonna cause problems.
Is 3-down the "unplaylisted tunes" playlist? Or maybe that's tunes in the root playlist. Position there wouldn't be automatically controlled by jEmplode unless you set a sort order on Root (can you do this even? I'm not sure).
As far as the timeout on retries thing, someone else mentioned this too. It's kind of problematic, because if your Empeg decides to do a rebuild, that is totally dependent on the number of tracks you have on your player, so that could take 30 seconds or it could take 20 minutes. It's really hard to come up with a meaningful timeout. Now if someone wants to do the legwork of determining what the equation is for rebuild time as a function of number of tracks, then I could probably work that in there somehow to make it a little smarter.
For the rebuild thing, a sync failure is a case where I can't rebulid on the PC because the Empeg is in an unknown state relative to the in-memory database, so I have to fall back to an Empeg rebuild there. I can only rebuild the database in-memory when it's a succesful sync, because then jEmplode's view of the database matches the Empeg's view of the database. If the Empeg just died somewhere in the middle, jEmplode can't necessarily know in every case what the Empeg ultimately decided to keep vs toss.
#237196 - 11/10/2004 12:40 Re: jEmplode and song Position [Re: mschrag]
woops
MSCHRAG,
The Down Button pressed 3 times plays the entire music database.
With a large database, it is CRITICAL to avoid the "rebuilding music database" because the times involved are so long. Usually, it ends up having to do this TWICE each time jEmplode gets working which results in a massive waste of time. I would say if you could put in some kind of "smart" rebuild time as you mentioned that would go a long ways for avoiding the "rebuilding music database" problem by increasing the chance of completing a resynch. i can't recall if 16000 took 40 minutes per rebuild or 40 minutes to get jEmplode back up which is 2 rebuilds.
#237197 - 11/10/2004 13:33 Re: jEmplode and song Position [Re: woops]
mschrag
Loc: Richmond, VA
jEmplode 69 does in-memory rebuilds if you turn it on in Options. It just can't do it when a sync fails.
#237198 - 11/10/2004 17:00 Re: jEmplode and song Position [Re: mschrag]
woops
MSCHRAG,
Yes, i understand that now. I was referring to increasing the time for the resynch to occur when there is a large database in order to avoid empeg "rebuild music database" .
Also,
why does there seem to be 2 reboots at the end of a resynch? After an upload, I will hear music from the empeg a little and then it will reboot and then play as usual? Is there any way to make the music come on just one time, when it is ready?
#237199 - 11/10/2004 17:57 Re: jEmplode and song Position [Re: woops]
mschrag
Loc: Richmond, VA
You said your database rebuilds twice per upload? So are you saying that because the timeout expires waiting for a reboot, that somehow causes a SECOND rebuild to happen? That on-empeg-rebuild should only happen if the original sync failed in the first place. A normall process is: upload changes, jEmplode requests database rebuild (you should see the rebuild status in jEmplode), jEmplode reboots player, player reboots (and does not rebuild), player finishes loading, jEmplode reconnects to player, done.
The timeout should happen if it goes like this:
upload changes, jEmplode requests database rebuild, rebuild fails, Empeg reboots and rebuilds itself, jEmplode waits and times out.
I'm not sure where the second reboot or rebuild would happen in this process or for that matter why your Empeg would be rebuilding itself. Are there any error messages that jEmplode displays? Can you run a full sync and send me the console output from that? (also, if you would, turn off serial/usb so those exceptions don't get all mixed up with the other debug info in the logs).
ms
#237200 - 11/10/2004 22:55 Re: jEmplode and song Position [Re: mschrag]
woops
MSCHRAG,
Let's say on a resynch, there is a time out and the empeg is left in a state of "synchronising". You have to reboot. That is where the two "building music database" rebuilds come in.
VERY frustrating when you have a large database.
#237201 - 11/10/2004 23:05 Re: jEmplode and song Position [Re: woops]
mschrag
Loc: Richmond, VA
So this is the part I'm not clear on -- when you say "resynch" can you clarify? What is happening in the jEmplode sync dialog at this point? I'm just trying to think of a point in the protocol where a timeout would occur that would leave "Synchinsing.." on the Empeg. It's certainly not SUPPOSED to happen this way. There's definitely something funky going on w/ your scenario, I just don't know what yet.
#237202 - 12/10/2004 06:19 Re: jEmplode and song Position [Re: mschrag]
mdavey
Loc: Wellingborough, UK
I see this quite a lot. Windows XP+SP2, JEmplode 61, Ethernet connection, v3aplha7+Hijack413. Approx 6.7 GB of a 9 GB drive is used. I do have some other things on the system (ttsclock, empTelnet, web interfce).
JEmplode shows "Rebuilding music database" with approx 20-25% progress bar. Always stops at the same point.
I just put it down to the beta software.
Michael
Ex-owner of stolen empeg #030102741
#237203 - 12/10/2004 10:32 Re: jEmplode and song Position [Re: mdavey]
mschrag
Loc: Richmond, VA
mdavey -- So it just hangs at 25% of rebuilding? So at this stage your Empeg is just left in Synchronizing mode like he's talking about as well?
Would you mind running jemplode from the commandline (java -jar jemplode.jar) get it to hang and leave it just couple a minute or two then send me the console output?
Also, I'd be interested to see you do a Ctrl-Break (in the console) when it's hung and send me that output as well.
#237204 - 12/10/2004 11:51 Re: jEmplode and song Position [Re: mschrag]
mdavey
Actually, looking again, I'd say the status bar reads more like 33%. Also, when the rebuild suceeds, it takes an age to get to 33% then jumps to 66% and then 100% very quickly.
Yes. Eventually, jemplode will time out and bring up a wide error dialogue box. Even then the Empeg thinks it is synchronising.
Would you mind [getting some diagnostics]
Okay. I've just tried to reproduce the problem but failed. Perhaps it isn't as common as I thought! I'll keep trying.
The following could be completely unrelated:
Synchronisation seems to take quite a lot longer with recent hijacks installed. I need to time it to be sure, but that is my impression.
Also, rebooting (either via Hijack reboot, Hijack force AC/DC mode or the command that jemplode sends) will often cause the Empeg to lock up - it goes into standby with the flashing LED but can't be woken up via the front buttons or keypresses on the serial console. Also telnetd isn't responding at this point. The console has about 8 lines of "(data ab(d(d(((data((((((((d(da((((d(d(((((((((" ending with "(data abort vector)". Perhaps something is running out of memory? This is a 32MB player and seems stable otherwise.
It may be that the jemplode problem is related to the need to fsck the disks - ISTR that jemplode often does something extra when first started (during a session where the sync fails) compared to a jemplode session where the sync is fine. I need to see it fail a few more times to know if this is the case or not.
Hope I've helped rather than confused.
Michael
