Page 1 of 4 1 2 3 4 >
#249308 - 14/02/2005 16:14 Power
Happy Birthday schofiel
More Power, Igor, More Power! (Bwa ha ha ha haaah)
Only one choice allowed
Votes accepted starting: 14/02/2005 23:13
View the results of this poll.
#249309 - 14/02/2005 16:17 Re: Power [Re: schofiel]
Annoying BBS feature...the start of a poll is local to the poster. I can't vote till 8:13 pm ( it is now 1:17 EST).
#249310 - 14/02/2005 16:23 Re: Power [Re: schofiel]
Actually, my favorite are the new style of wall warts, like the plug-top adapter that some Rio Car owners got. It's a wall wart that doesn't cover up the other plugs. Best invention since the Tivo.
There's also this, which has been marketed to musicians for many years, but really should be going for the mainstream too.
#249311 - 14/02/2005 19:36 Re: Power [Re: tfabris]
Unless your power strip has turned its outlets 90°.
[Wall Wart Remover]
I guess I know which way you voted in the poll, then.
#249312 - 14/02/2005 19:37 Re: Power [Re: schofiel]
How about putting a power supply in the damned devices, you lazy-ass engineers?
#249313 - 14/02/2005 19:43 Re: Power [Re: schofiel]
matthew_k
Yeah, I think I'd have to go with power bricks, but not too many things these days come with them.
How dificult would a universal DC power supply system be? I'd sure like to have some sort of universal "DC Power Cent(er)/(re)" that had perhaps 12v and 5v rails that had a standard socket/cord sytem that multiple DC lovin' appliances could plug into? Are there serious disadvantages in forcing electronics to pick betwen 5 and 12 volts?
#249314 - 14/02/2005 19:46 Re: Power [Re: wfaulk]
Some products I agree with this, others it makes a lot more sense to go outboard.
#249315 - 14/02/2005 20:07 Re: Power [Re: matthew_k]
There's something like that for guitar effets pedals, so it's certainly doable, but it'd make more sense to me to be able to have a variable setting for each output port. I don't think that size is too big a concern. I don't know why someone hasn't done something like that before.
#249316 - 14/02/2005 20:09 Re: Power [Re: JBjorgen]
jimhogan
Loc: Seattle, WA, U.S.A.
Obviously Rob's hope is that all of his "Euro" pals will vote and those of us in lesser time zones in the West West will get discouraged by the exit polls and just decide "Screw it! Why bother? It won't make any difference anyway!"
Jim
#249317 - 14/02/2005 20:32 Re: Power [Re: jimhogan]
Hang on - I posted this on the 14th (today) and I enabled immediate voting - yet it chose the timezone of the BBS and has even locked me out, dammit!!!
#249318 - 14/02/2005 20:36 Re: Power [Re: wfaulk]
Ezekiel
Loc: NH USA
Bitt,
Sadly, the power supply outside the device issue has much more to do with power regulations than engineers. If you had any idea how much crap you have to go through to get a device CE, CSA, UL, AU/NZ certified, you'd know why there are external power supplies. Getting these certs not only takes effort, it can take time, LOTS of it. Months if you company is too small to have a self-certifying lab. It can also cost tens of thousands of dollars. Essentially if you're making a device that uses AC power, you have to submit & test every device in every regulatory market. By using outside power supplies you just get the supply and go, as the supply manufacturer already has the certifications needed. Devices using power <42V DC (the low-voltage directive) do not need to go through this rigamoarole, so all your electronics will use these external power supplies until the day that a)regulations change or (more likely) b)hell freezes.
-Zeke
WWFSMD?
#249319 - 14/02/2005 20:36 Re: Power [Re: jimhogan]
StigOE
Don't think so. At least, if that was what he wanted to do, then he failed...
Votes accepted from (15/02/2005 02:13)
Stig
#249320 - 14/02/2005 20:41 Re: Power [Re: Ezekiel]
Oh. Good point. Someone needs to devlop a standard modular system, then. The engineers leave a hole with a standard connector of some sort and then ship a standardized-upon power adapter that fits in that hole.
#249321 - 15/02/2005 05:11 Re: Power [Re: schofiel]
I hate wall warts enough that, even though I don't know what a power brick is, I picked the first option -- can't be as bad as those damn wall warts.
#249322 - 15/02/2005 08:04 Re: Power [Re: matthew_k]
bonzi
Exactly. Power supplies for my phones, PDAs, cameras, radios and other miniaturised gadgets are often bulkier and almost always heavier than the devices they feed, and, needless to say, mutually incompatible. Solving this problem should be simply a matter of standardization.
#249323 - 15/02/2005 12:11 Re: Power [Re: bonzi]
boxer
Loc: Yorkshire UK
I have a little gizmo from Maplins in a spare slot in the back of my PC, which works brilliantly, doing away with bricks and plug tops, and is sufficient for my Empeg, Karma and 35mm slide and neg. scanner (Which cost exactly half the Amazon UK price from a little shop in Delft, last year). I would put a link, but I can't find one in the Maplin catalogue
#249324 - 15/02/2005 12:30 Re: Power [Re: boxer]
bonzi
Ah, so the things do exist! If you run into the link, please post it.
I have only seen 'universal' wall warts with switch selecting output voltage and a hedgehog-like cluster of plugs at the end of the cable: usually non-regulated, with inacurrate voltage, underpowered and all too easy to accidentally bump up the voltage, reverse the polarity or short the terminals - in one word, useless.
#249325 - 15/02/2005 13:25 Re: Power [Re: boxer]
I know exactly what you mean and I saw it in Maplins yesterday, however I can't remember the cat number and I don't seem to be able to find the right combination of words to find it on their website.
#249326 - 15/02/2005 13:45 Re: Power [Re: canuckInOR]
jimhogan
Exactly. And that's how I voted (now that Rob's conscience got the better of him and he opened voting up to North Americans!)
Jim
#249327 - 15/02/2005 14:01 Re: Power [Re: bonzi]
boxer
Loc: Yorkshire UK
It's here as "Power (I/O)", about halfway down the page and 2/3 rds of the way across. For some reason, the "More Info" link is dead.
#249328 - 15/02/2005 14:02 Re: Power [Re: boxer]
Ahh Godfrey, your search-fu is much stronger than mine.
#249329 - 15/02/2005 14:06 Re: Power [Re: andym]
boxer
Loc: Yorkshire UK
If you've worked with the filing system in my office, you'll have developed a razor sharp appreciation of the illogical!
#249330 - 15/02/2005 14:36 Re: Power [Re: schofiel]
boxer
Loc: Yorkshire UK
Of course, if the US had adopted a sturdy three pin plug large enough for an astronaut to plug his razor in with certainty whilst weightless in space, none of this would be being discussed. The average UK plug top will house a family of four, transforming from 230 to 12v can be accommodated in one small corner of the available space: You just have 2 puny little pins.
I remember the days when they came in three different sizes and people also had the option of burning the house down by plugging the toaster in to the light fitting with a bayonet plug: Another fundamental difference between our two lands, we have bayonets, you have screw fittings (Although we seem to be wavering between the two, probably because of some European Community directive to stamp out unfair prejudice in light fittings).
Whilst I'm on the subject, who invented those wretched halogen lamps that flush mount in the ceiling: I spend my life balancing on a kitchen stool. The mains ones pop just as quickly as the 12v ones.
Yes, and those low consumption, long life bulbs: So they may be - except when you put them in an outside light fitting that requires borrowing the ladder of the neighbour you don't like and getting the wife to stand at the bottom screaming hysterically that she can't hold on much longer. Then it is absolutely mandatory having taken those risks that the bulb that you've bought from B & Q doesn't fit inside the glass globe. When you go back Tracey, or whatever her name is, won't budge on changing the bulb, if you don't have the receipt, although you've got the bag, packing and credit card slip.
And as for that high power light with the PIR over my neighbour's garage, is it fair, when I creep out surreptitiously with the boxers for a late night wee, dressed only in underpants, towelling dressing gown and Hunters, that I should be illuminated with 2000watts of power?
#249331 - 15/02/2005 14:52 Re: Power [Re: boxer]
RobotCaleb
wouldnt it be easier to creep into your bathroom for a late night wee?
#249332 - 15/02/2005 15:06 Re: Power [Re: RobotCaleb]
Er, he means Boxer dogs, not boxer shorts.
I hope.
#249333 - 15/02/2005 15:31 Re: Power [Re: matthew_k]
n6mod
Loc: Berkeley, CA
Actually, for a lot of devices, there is an emerging standard for 5V power: USB
I have a Cig. lighter plug with a USB A connector on it, that I use variously to charge my cell phone, run my GPS, &c.
Conveniently, my laptop has standby power on USB when plugged into AC power, so I can just carry one power brick for the laptop, and use the 4 convenient charger outlets on the side.
And the original iPod (at least) did the same with 12V and Firewire, though that's less common.
-Z
-Zandr
Mk.IIa #010101243 currently getting a 500GB SSD. More spares in the shed.
#249334 - 15/02/2005 15:34 Re: Power [Re: n6mod]
robricc
You need this then.
#249335 - 15/02/2005 16:05 Re: Power [Re: n6mod]
Which is actually a really hideous hack since you're not supposed to draw power from the USB port without actually telling the host/hub how much you'll be drawing. A lot of the devices actually try to draw more than the 500mA that you're allowed on each port if it's self powered.
#249336 - 15/02/2005 16:07 Re: Power [Re: wfaulk]
Putting a PSU into a device can potentially reduce it's life span as well since you're increasing the internal temperature. Also if the PSU packs up it's easier with an external PSU to get it fixed/replaced.
#249337 - 15/02/2005 16:16 Re: Power [Re: boxer]
The UK plug is vastly overengineered. It's nearly indestructible though and at a guess those solid brass pins can probably pass at least 40-50A. Good plug until you tread on an upturned one...
I don't mind wallwarts so long as they're the small SMPS style which don't overhang anything. I hate the old chunky linear ones you'd get on cheap equipment which were huge, heavy and inefficient. Usually if I get anything with one then I replace it with a small brick on a leash style one or a tiny wallwart.
