#251089 - 04/03/2005 11:00 Remapping tel Mute
Will
Loc: Plymouth, UK
Hi there,
I want to remap the tel mute signal to switch it to the aux in...so that the sound come throught the speakers. I know that you can do it in hijack, I just cant find the thread that said how. Can anyone remember how to do it?
Anyway, I think I might have just broken a record for the bbs. I've been a member and regular viewer from it's inception and this is my first post!
Thanks in advance
#251090 - 04/03/2005 14:19 Re: Remapping tel Mute [Re: Will]
[hijack]
extmute_on=button
extmute_off=button
#251091 - 04/03/2005 14:26 Re: Remapping tel Mute [Re: mlord]
loren
Mark beat me to it. Funny though. That's actually your 9th post, but your first one was also about phone mute, 4 years ago! =]
|| loren ||
#251092 - 04/03/2005 14:43 Re: Remapping tel Mute [Re: loren]
Heh, but 4 years ago, I don't think Hijack existed, or at least it didn't have that feature.
#251093 - 04/03/2005 15:12 Re: Remapping tel Mute [Re: Will]
Will
Loc: Plymouth, UK
Hey, thanks for the prompt replies. Goes to show what my memory is like! I'll give it a go when I get home.
Loren, I've now got my empeg in the Scooby but the installers cocked it up, so I'm getting another fascia surround and going to re-do it
#251094 - 04/03/2005 15:14 Re: Remapping tel Mute [Re: Will]
SE_Sport_Driver
Another facia surround ? ? Those are like 80 bucks! I hope you didn't have to pay for it!
#251095 - 04/03/2005 15:33 Re: Remapping tel Mute [Re: Will]
Will
Loc: Plymouth, UK
I have friends in important places...i.e. his Father owns the local Subaru dealership, so 'm hoping it won't be too bad.
#251096 - 15/01/2006 19:52 Re: Remapping tel Mute [Re: Will]
estocks
Loc: Reading UK
Hello
I have two questions I hope you can answer; 1/ does the telephone mute require enabling as mine is not responding to a GND? and 2/ can the output of the mp3 audio be attenuated instead of muted?
Sw is v2.0 hijack (aging hijack)
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#251097 - 15/01/2006 19:55 Re: Remapping tel Mute [Re: estocks]
Yes, I think you control whether it's enabled by using the "Configure Player" screen in Emplode.
#251098 - 15/01/2006 20:39 Re: Remapping tel Mute [Re: estocks]
matthew_k
It can be attenuated, but as far as I know you're not going to get it to mix the mp3 sound under the aux in.
#251099 - 15/01/2006 21:53 Re: Remapping tel Mute [Re: estocks]
You can map the mute high/low signals to do anything you want them to do via Hijack's button remapping. Somebody here has used this in the past. Try the "Search->Google" to look for that.
#251100 - 16/01/2006 22:29 Re: Remapping tel Mute [Re: mlord]
You basically gave the required info in the second post of this thread I think Mark.
[hijack]
extmute_on=Hush
extmute_off=Hush
should work I think however there is potential for it to get out of sync if the player isn't running when extmute goes active. Alternatively some kind of "Volume+, Volume+, Volume+, Volume+, Volume+" (and appropriate Volume- codes) sequence would work although it would suffer the same sync issues possibly.
As for actually getting the line to work, from memory it will default to the low/GND state i.e. applying GND won't do anything - you need to apply +12V to see anything. Have you seen this?
