#251437 - 10/03/2005 09:23 well...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v417 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Sat Jan 15 19:12:21 EST 2005
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: passed.
c2100000: passed.
c2200000: passed.
c2300000: passed.
c2400000: passed.
c2500000: passed.
c2600000: passed.
c2700000: passed.
c2800000: passed.
c2900000: passed.
c2a00000: passed.
c2b00000: passed.
c2c00000: passed.
c2d00000: passed.
c2e00000: passed.
c2f00000: passed.
c3000000: passed.
c3100000: passed.
c3200000: passed.
c3300000: passed.
c3400000: passed.
c3500000: passed.
c3600000: passed.
c3700000: passed.
c3800000: passed.
c3900000: passed.
c3a00000: passed.
c3b00000: passed.
c3c00000: passed.
c3d00000: passed.
c3e00000: passed.
c3f00000: passed.
empeg-car player (hardware revision 9, serial number 10101539) 64MB DRAM
Command line: mem=16m
Memory: 63676k/64M available (984k code, 20k reserved, 852k data, 4k init)
Dentry hash table entries: 8192 (order 4, 64k)
Buffer cache hash table entries: 65536 (order 6, 256k)
Page cache hash table entries: 16384 (order 4, 64k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 65536 bhash 65536)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005c80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-206000, ATA DISK drive
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:03
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...&#8226;Ô&#8226;j½Õ¹Ñ&#8226;&#8216;&#65533;ɽ½Ñ&#65533;¡&#8226;áÑÉ&#65533;&#8482;¥±&#8226;ÍåÍÑ&#8226;µ¥&#65533;É&#8226;&#8230;&#8216;½¹±å¹)5ÿchange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
#251438 - 10/03/2005 09:33 Re: well... [Re: pca]
AudunE
Loc: Trondheim, Norway
Nice work!!!
- Audun E -
#251439 - 10/03/2005 10:06 Re: well... [Re: AudunE]
Excellent work!!!
#251440 - 10/03/2005 10:11 Re: well... [Re: pca]
petteri
Loc: Helsinki, Finland
Great work!
#251441 - 10/03/2005 12:28 Re: well... [Re: pca]
SE_Sport_Driver
I can't believe how flush mounted that is!
How is 2.01 handleing the extra memory?
#251442 - 10/03/2005 13:43 Re: well... [Re: pca]
DeadFire
Sweet. Gimme gimme gimme.
#251443 - 11/03/2005 12:21 Re: well... [Re: pca]
bjoern
Loc: Regensburg, Germany
Cool!
Will that work with players that already have the piggy-back upgrade?
32MB, serial: 10101626
#251444 - 11/03/2005 12:46 Re: well... [Re: bjoern]
Not that I know of. I wish...
#251445 - 11/03/2005 13:25 Re: well... [Re: bjoern]
AudunE
Cool!
I think so, but you would only get 64MB total memory...
- Audun E -
#251446 - 11/03/2005 19:14 Re: well... [Re: bjoern]
The board has 4 banks of 16MB each, and the banks can be enabled/disabled independently. So, in theory, of you already had for example 32MB, you would turn off the first two banks. The other two would bring it up to 64MB. This is what you do with a MK2A anyway, as it already has one bank fitted.
#251447 - 21/03/2005 16:40 Re: well... [Re: pca]
bbowman
Loc: Virginia, USA
So where do I send the money? - and if I send it in US Dollars, would $132 be the right amount for you? I want one of these, badly
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
#251448 - 21/03/2005 17:45 Re: well... [Re: bbowman]
Assuming the price and P&P is still correct from the other thread then it'd be £100 + £10 which is about $208.728 at the moment.
#251449 - 22/03/2005 02:38 Re: well... [Re: pca]
peakmop
Loc: 384400 km from the Moon
Excellent work, Patrick.
This is truly the cleanest memory upgrade ever!
All we need now is the link to the order page...
