#251899 - 17/03/2005 01:07 Wireless AP placement?
I've been having problems with my laptop loosing connection with my AP. The distance between the two is less than 20' with a clear line of sight. The thing is, it and the cable modem are setting on the floor near the wall. Its a concrete floor.
Is this a less than optimum placment, setting on the floor?
For what its worth it's a linksys wrt54gs running Satori 4.0 firmware. The laptop has an intel pro/wireless 2200bg setup.
#251900 - 17/03/2005 01:30 Re: Wireless AP placement? [Re: gbeer]
matthew_k
If they're really 20 feet apart, I'd suspect interference before I suspected antena placement problems. Are you using a 2.4ghz cordless phone? The microwave? Are your neighbors? Changing the channel might help, and switching to 802.11a will really help.
#251901 - 17/03/2005 01:43 Re: Wireless AP placement? [Re: gbeer]
Try moving the AP 3" closer or further away from the wall, just in case it's a victim of Raleigh fading from wall reflections.
#251902 - 17/03/2005 01:53 Re: Wireless AP placement? [Re: matthew_k]
I haven't been able to find a phone in use coincedent with the laptop's fuzzing out. There is a neighbour with a Belkin54g that I sometimes see listed, but it's a really low signal. I've switched channels away from him. I'm now on 11. Could it be that his ap is bouncing around the spectrum and only sometimes causing interference?
I suspect the Belkin is running out of the box settings, without any security. Mine's about as tightly locked down as I know to make it. (wep and mac filtering both on)
#251903 - 17/03/2005 19:06 Re: Wireless AP placement? [Re: gbeer]
In addition to Mark's advice, try lowering the output power. It can help at close range.
#251904 - 18/03/2005 00:38 Re: Wireless AP placement? [Re: frog51]
Well It's off the floor now, about 4ft up and a foot from the wall. Things seem to be better. It's definatly related to the times I see the Belkin appear in the wireless networks paine.
O.T. comment. I realize saying strange and Windows in the same sentence is redundant, but I find it strange that Windows announces when it reaquires a wireless connection but not when it looses one.
