#254316 - 15/04/2005 13:59 jEmplode 69.01 hangs while upgrading hijack v424->v425
Mataglap
Argh. Screenshot attached.
(yes, I'm running v3alpha8 -- I'm one of those crazy ogg people. But this is a hijack upgrade which uses hijack's kftpd to write to the firmware memory location, if I understand all the bits right.)
While jEmplode works great most of the time, I get this cases where it seems to hang. This is the first time it wasn't during song uploads, but it's in the middle of a hijack upgrade. Nothing has changed for the last 30 minutes, so I guess it's abort and see what I need to do to get back to normal.
This is sort of a companion thread to the one I started a few days ago, and all of the deails are the same. I've upgraded hijack with jemplode at least three times this week, the player was freshly booted before starting jEmplode, and there is only the ksock -104 messages on the console.
Anyone have any suggestions before I start closing programs and throwing 'kill's around?
--Nathan
#254317 - 15/04/2005 14:57 Re: jEmplode 69.01 hangs while upgrading hijack v424->v425 [Re: Mataglap]
Mataglap
I just closed the upgrade progress window and then quit jEmplode. Restarted jEmplode and the upgrade stalled briefly about the same point but then completed sucessfully. Whew, I was afraid I'd have to do a full empeg image reload because the flash was zapped or something.
--Nathan
#254318 - 15/04/2005 19:28 Re: jEmplode 69.01 hangs while upgrading hijack v424->v425 [Re: Mataglap]
The first stall was probably due to the kftpd bugs I added in v423/v42 -- ftp still worked, it just wasn't exiting properly.
So jemplode hung on the kernel upgrade *after* it was upgraded.. so no harm done. Your second attempt then just overwrote the same kernel again for good measure.
I *think* v425 is now just fine, but I don't have an empeg anywhere near me right now -- I took the train to Toronto for the weekend.
#254319 - 15/04/2005 21:06 Re: jEmplode 69.01 hangs while upgrading hijack v424->v425 [Re: mlord]
Mataglap
Mark,
Enjoy your weekend!
Hijack v425 did suppress the kernel level ksock ... -104 error message, but it's still being displayed when it gets passed up to kftpd.
kftpd: ksock_rw() failed, rc=-104
Not a problem, tho'
Thanks again!
--Nathan
#254320 - 15/04/2005 23:10 Re: jEmplode 69.01 hangs while upgrading hijack v424->v425 [Re: Mataglap]
Okay, thanks. I've added a one-liner to take care of that now, for whenver v426 gets released.
