#260314 - 13/07/2005 13:06 MK II A Jumpers
kendrick
Can anyone tell me if all the small red jumpers on the MK II A are needed? Cause im missing one of those jumpers, im missing the one nearest the Car Plug.
Here's a picture of the jumper im missing? THe player seems to be working fine without it, im just wondering if there is any long term danger?
http://www.illzy.com/car_mk2_4.jpg
Edited by kendrick (13/07/2005 13:20)
#260315 - 13/07/2005 13:36 Re: MK II A Jumpers [Re: kendrick]
Isn't that a Mk2?
#260316 - 13/07/2005 13:41 Re: MK II A Jumpers [Re: tman]
kendrick
Yes that picture is, but it looks the same as the board i have now. I have a rio branded empeg so im assuming its MK II A
#260317 - 13/07/2005 14:05 Re: MK II A Jumpers [Re: kendrick]
It must be a Mk2 since the Mk2A only has two RAM chips.
You should put a replacement jumper on though. I think it's the 5V line to the HD and you really need both since the drives draw quite a bit of current.
#260318 - 13/07/2005 14:08 Re: MK II A Jumpers [Re: tman]
kendrick
WIll it work without the jumper temporarily, because i dont know where to find a jumper that small and if i did i would have to order it and wait for it to come in.
#260319 - 13/07/2005 14:19 Re: MK II A Jumpers [Re: kendrick]
You'll have to wait for Patrick or Hugo to answer that one. It should be a 0.1" jumper though and most PC hardware uses the same size jumpers.
#260320 - 13/07/2005 14:38 Re: MK II A Jumpers [Re: tman]
RobotCaleb
I don't think that picture is of the hardware that he is working on. At least, that's what I got from reading his statements.
kendrick, is this correct?
#260321 - 13/07/2005 14:42 Re: MK II A Jumpers [Re: RobotCaleb]
#260322 - 14/07/2005 18:22 Re: MK II A Jumpers [Re: kendrick]
schofiel
Well, that's either the 10V or 5V analogue rails. You won't get any audio output without it!
I have lots of them. You can use jumpers from mini drives.
