Thanks Tony. Yes it does. The buttons dim when the display dims, but they are never completely off when the headlights are off. I never really gave this much thought until someone was complaining that their button lights "work in reverse", ie. headlights on= button lights off, headlights off= button lights on. I was not aware that the button lights ever turned on and off in response to the headlight status.
So is it possible to get the button lights to turn off completely with the headlights off and on when the headlights are on, if the right config.ini syntax is used?
Thanks,
Stu
