#295216 - 13/03/2007 00:36 Regedit permissions in AD
lectric
Loc: New Orleans, LA
Ok guys, another question... I currently have a need to distribute a .reg file to a hundred or so users running win2k on a win2k3 AD. The problem is, these users do not have admin rights on their PC, so them editing the registry is not going to work. I currently use Kix to do all the logon scripting, but I'm not sure that I can have it add reg files, since the user permissions have kicked in as soon as they log in.
After the reg file in imported, I then need to run another script that resets a windows default. Again, they don't have the security access to run the script.
Can I use group policies to accomplish this? I see how to grant access to a very specific part of the registry, which may solve my first problem, but what about the second?
I also see how I can use group policies to add a startup script, which I believe runs before the user logs in. Could that do it?
#295217 - 13/03/2007 00:47 Re: Regedit permissions in AD [Re: lectric]
Attack
Loc: Florida
This link seems to have some good info. You might need to make a temp user with admin access and then delete the user.
Chad
#295218 - 13/03/2007 00:52 Re: Regedit permissions in AD [Re: Attack]
lectric
TYVM for the link. Lotsa reading ahead.....
#295219 - 13/03/2007 01:02 Re: Regedit permissions in AD [Re: lectric]
lectric
Couple of things.... Looks like startup/shutdown scripts SHOULD work, for both cases. The only drawback is that they are only run on actual startup/shutdown. A regular login is NOT enough.
Second, I SHOULD be able to use runas, but I don't see a way to enter a password. Using kix, I could tokenize the script, so entering a password wouldn't be a real issue. I just REALLY don't want to have to give out an admin password. I guess I could create an account that has local admin rights only and make the password something really easy to type in, but I shouldn't HAVE to. There HAS to be a way to fully automate it.
#295220 - 13/03/2007 01:53 Re: Regedit permissions in AD [Re: lectric]
Attack
Loc: Florida
I was thinking of creating the user without a password but after reading this I see that the runas command does work when a user doesn't have a password.
Chad
#295221 - 13/03/2007 02:27 Re: Regedit permissions in AD [Re: Attack]
lectric
Exactly. I seem to have come across a util that will do it. CPAU
Whatcha think? I tested it on my machine here, and it seemed to work, that is, I ran edit as another user, and when I saved the file, it was saved with the test user as owner, not me, and I was logged in as me. Wow that's a lot of commas.
Thanks a million for the feedback, btw. I was hitting a wall and that link opened up a lot of possibilities. Nice thing is that I can tokenize the script with it, and the end user never gets to see the password.
Edited by lectric (13/03/2007 02:29)
