#297550 - 24/04/2007 17:44 Can you help me find a light bulb? (USA)
petteri
Loc: Helsinki, Finland
I need to replace some bulbs in a fixture above my kitchen sink. The bulbs I'm replacing are 50w halogen flood types with a GU10 base.
I'd like to replace these with a compact fluorescent type. They seem to be prevalent in the UK as google comes up with resellers there. Right now the fixture is on a dimmer, but that can be swapped out. Can anyone find them in the USA? The local Home Depot only had a 35W equivalent.
#297551 - 24/04/2007 18:28 Re: Can you help me find a light bulb? (USA) [Re: petteri]
Have you looked for LED-based bulbs? For that size, they seem more common. Of course, you may not want LED.
#297552 - 24/04/2007 18:59 Re: Can you help me find a light bulb? (USA) [Re: wfaulk]
petteri
Thanks for the suggestion. I'm not sure if I'm ready to plunk down $38 a bulb for the LEDs yet. I need five of them for this fixture. Here is the only place I've sourced the LED lights so far:
LED GU10 base bulb
#297553 - 24/04/2007 19:29 Re: Can you help me find a light bulb? (USA) [Re: petteri]
It seems that the life on the halogen ones is 2000-4000 hours. If the estimate on the LED one of 100,000 hours is accurate, that might not be such a bad investment.
#297554 - 24/04/2007 21:06 Re: Can you help me find a light bulb? (USA) [Re: petteri]
Attack
Loc: Florida
Amazon seems to have a few GU10 LED bulbs.
Chad
#297555 - 24/04/2007 21:46 Re: Can you help me find a light bulb? (USA) [Re: Attack]
petteri
Good suggestion, but I think these will be too dim for use in the kitchen. I never check Amazon for these things!
I bought this house from an older couple and nothing is at all energy / environmentally efficient. The shower heads that were in the shower emptied out the 40 gallon hot water heater in just a few minutes! Old toilets, single pane jalousie windows, etc...
#297556 - 24/04/2007 21:53 Re: Can you help me find a light bulb? (USA) [Re: petteri]
petteri
I did find this on eBay...
eBay LED GU10
ships from Honk Kong...
