Here is another boot log for my mkIIa empeg....I cannot get past the Rio digital audio logo.....it hangs there....Help!
empeg-car bootstrap v1.02 20001106 ([email protected])
or forever hold their peace...it seems not. Let fly the Pen
e000 v1.04st: wrote
Copying kernel...wrote 0x5
Calling linux kernel...
empeg
T
ide_data_test: wrote 0xffff read 0xffa5
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 ([email protected]) (gcc versions, se
id
2.95.3 20010315 (release)) #2 Tue Sep 4 09:18:20 EDT 2007
ide_dat
hda: ST9100823A, ATA DI
Processor: Intel StrongARM-1100 revision 9_data_test: wrote 0x0000 read 0xffa5d 0xff
Checking for extra DRAM:lt=0 on
c1000000: wrote ffffffff, read e28cc001
ide_data_test: wro
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.st: wrote 0x
empeg-car player (hardware revision 9, serial number 30102295)
POSIX conformance testing by UNIFIXki
Linux NET4.0 for Linux 2.2itialized100823A, ATA DISK
smc chip id/revision 0x3349_data_test: wrote 0x0000
smc9194.c
IP Protocols: ICMP, UDP, TCPman ([email protected])
TCP: Hash tables configured (ehash 16384 bhas
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART: Mounted root (ext2 filesystem).0x55a5ll result
Signature is 20706d65 'emp '
Found custom animation at offset 0x99380)
hda: ST
Tuner: loopback=0, ID=-1 pump...VFS: Mounted roo
show_message("Hijack v479 by Mark Lord")
empeg display initialised.ide_data_test: wrote 0x000
empeg dsp audio initialised
empeg dsp mixer initialisedoot has d_count=1
empeg dsp initiali
empeg RDS driver initialised
empeg power-pic driver initialised (first boot) peace...it seems not. Let fly the Penguins of
ide_data_test: wrote 0xaaaa read
empeg single channel IDE
e
Probing primary interface...
Copying kernel...
ide_data_test: wrote 0x0000 read 0xff80kernel...ide_data_test: wrote 0x
ide_data_test: wrote 0xffff read 0xff80Uncompressing Linux....................
ide_data_test: wrote 0xaaaa read 0xaa80
2.
ide_data_test: wrote 0x5555 read 0x5580:18:20 EDT 2007
ide_data_test: wrote 0x0000 read 0xff804.c:v0.12 03/06/96 by Erik Stahlman
ide_data_test: wrote 0xffff read 0xff80S: Mounted root (ex
Calibrating delay loop... 207.67 B
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9100823A, ATA DISK drive
hda: ST9100823A, 95396MB w/8192kB Cache, CHS=12161/255/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:f
7
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initKernel panic: No init found. Try passing i
nit= option to kernel.
Check out The Tremors the best hillbilly rock n roll you ever set your corn fuel soaked ears to.
MK2a 250gig #030102295
