#303248 - 19/10/2007 16:45 Cracking passwords on zip files
Someone at work has archived a load of stuff into a password-protected zip file. They now can't remember the password. Any pointers to something that could brute-force the p/w overnight?
#303249 - 19/10/2007 16:54 Re: Cracking passwords on zip files [Re: andym]
Several ZIP vendors have their own proprietary encryption. Is it one of those or is it the standard ZIP encryption?
Googling "zip crack" returns a lot of results. AZPR seems likely.
Edited by wfaulk (19/10/2007 17:00)
#303250 - 19/10/2007 16:59 Re: Cracking passwords on zip files [Re: wfaulk]
I'm pretty sure it's the just the standard encryption. Other protected files created by the same person can be opened with the Info-ZIP version of unzip on one of my linux boxes.
#303251 - 19/10/2007 17:05 Re: Cracking passwords on zip files [Re: andym]
You got a plaintext? If so then use pkcrack
#303252 - 19/10/2007 17:16 Re: Cracking passwords on zip files [Re: tman]
No, I don't have any of the original files to use as a comparison.
#303253 - 19/10/2007 22:17 Re: Cracking passwords on zip files [Re: andym]
I'd second AZPR - it's not the fastest I've seen, but unless you want to fork out for a good chunk of cash, it does the job.
