#304124 - 19/11/2007 00:29 Blinking Keyboard!!!
Spent several hours trying to figure out why my niece's computer was rejecting all login passwords. It's a new, well 6wks old HP Slimline machine sporting Vista.
What was crazy was that F10 would not let me get into the bios screen F8 often didn't get me to the safe mode choice screen, and when it did, the system never actually booted into safe mode.
Finally used this to clear all passwords. After that logins worked. Used the control panel to reestablish passwords, logged out/in switched users. It all worked. Rebooted the system, Baloowie. All passwords rejected again. Once more around the mulberry bush we go.
During this session, while trying to type a path I finally notice, I can't type "/". Only "?'s" show up. WFT??
Opening notepad and trying various keys, every thing typed seems shifted. Using shift or caps lock seems to cause changes, but it's inconsistent.
Go find another keyboard and swap it out and everything is fine.
Blinking Keyboard!!! Who would suspect that a brand new kbd would fail in such a flaky way.
#304125 - 19/11/2007 01:05 Re: Blinking Keyboard!!! [Re: gbeer]
I have seen keyboard failures cause much worse problems than that! When a keyboard gets old and starts sending a bit of noise along with the keycodes, it can do really bad things -- especially if it is something like my Gateway AnyKey which actually has a microprocessor and RAM in it for storing keyboard macros.
