#307094 - 09/02/2008 15:00 Trying not to panic: Linux fsck help needed !!!!
It looks I have had a failing PSU in my clarkconnect server. This may have caused some data problems just before/during failure.
I have replaced the PSU and the thing boots, but it fails the fsck check and kicks me out saying I need to complete a manual one, which I have done many many times, but I am just stuck in this loop.
it fails because "/dev/md1 :Resize inode not valid"
I am using the command line fsck -y to run the check and complete everything it asks.
What am I doing wrong? I have done several searches for the problem, plenty people asking the question by no one seems to have posted an answer.
Any help would be great smile
Cris.
#307097 - 09/02/2008 15:11 Re: Trying not to panic: Linux fsck help needed !!!! [Re: Cris]
I'm guessing it has something to do with the LVM setup and not really the filesystem at all. I'm not that familiar with Linux's LVM, though, so I can't really help, other than to point you in a different direction.
This thread suggests poking at it with gparted.
Edited by wfaulk (09/02/2008 15:16)
#307099 - 09/02/2008 15:34 Re: Trying not to panic: Linux fsck help needed !!!! [Re: wfaulk]
I have got it to boot up now, but I think I may have caused a few problems.
I followed this...
# debugfs -w /dev/md1
debugfs 1.35 (28-Feb-2004)
debugfs: feature ^resize_inode
Filesystem features: has_journal filetype sparse_super
debugfs: kill_file <7>
debugfs: quit
# e2fsck -fy /dev/md1
Which has worked, but I notice it now fails to mount /boot
Slimserver isn't working so I assume I have made things worse ????
Although I every other part of the system seems to be ok.
Help ????? smile
Cris.
#307100 - 09/02/2008 15:48 Re: Trying not to panic: Linux fsck help needed !!!! [Re: Cris]
Hmmmm, slimserver is working, just not the web interface ????
Apache is running ok, and the rest of Slimserver seems fine, weird?
Any suggestions ???
Cris.
#307101 - 09/02/2008 16:19 Re: Trying not to panic: Linux fsck help needed !!!! [Re: wfaulk]
/dev/md1 is linu-raid, not LVM.
Cris - kernel version, mdadm details etc would help
also look in dmesg to see if the raid is failing...
#307102 - 09/02/2008 16:21 Re: Trying not to panic: Linux fsck help needed !!!! [Re: LittleBlueThing]
sorry - huge type/post lag frown
It looks like filesystem corruption then - if so then the problem is you'll never know what to trust frown
Have a look in the apache logs to see if slimserver is complaining - gotta go now - I'll be around tomorrow if you're still having probs - good luck smile
#307103 - 09/02/2008 17:37 Re: Trying not to panic: Linux fsck help needed !!!! [Re: LittleBlueThing]
Great! Thanks! smile
Everything seems to be working for now, I got slimserver running by forcing a reinstall. I don't seem to have lost any files, but I am currently taking a backup just in case I do!
I'm not that good at linux stuff, but I will have another go in the morning. I may decide this is a good time for some upgrades anyway and go for a full re-install just to be on the safe side.
I will post some logs in the morning smile
Cris.
#307104 - 09/02/2008 18:31 Re: Trying not to panic: Linux fsck help needed !!!! [Re: LittleBlueThing]
Yeah, I meant LVM generically, not as a specific product. I hate it when people use a generic term as a specific name for a product, like MS's SQL Server.
