#314005 - 12/09/2008 21:54 Fax software
Several computers ago, I was able to send files as faxes, not to other computers, but to actual fax machines. I don't recall what software I had that let me do that. The fax option just showed up as another system printer that would dial the number and transmit the image as a fax.
I now have internet and VOIP telephone service through a cable modem on a new computer. Can I use my computer to send faxes to fax machines? What special software and/or hardware do I need? I don't need to receive faxes, just send one every once in a while.
Probably be easier to just find someone who'll let me use their fax machine, or e-mail the file to someone with a fax machine...
#314006 - 12/09/2008 22:03 Re: Fax software [Re: tanstaafl.]
rubennyc
Assuming your service lets you use standard telephones (like Vonage), buy yourself a $5 splitter so you can connect a line from the VOIP modem to both your phone and the modem on your PC. Then, it should work the same way it always did.
#314011 - 12/09/2008 23:11 Re: Fax software [Re: rubennyc]
...connect a line from the VOIP modem to both your phone and the modem on your PC. Then, it should work the same way it always did.
Modem on my PC? I don't think there is one. This is a different computer from the one I used to send faxes on.
#314012 - 12/09/2008 23:14 Re: Fax software [Re: rubennyc]
There are services like eFax that will let you send and receive faxes from a computer. There free service is receive only, for which you get a non-local number and they e-mail the faxes to you. For out going they charge, and it is a monthly fee of ~$20, not worth it for hte odd fax.
I mention all this because I assume that there are similar services available from others, one of which might be a pay-by-the-page.
