#312858 - 11/08/2008 14:52 Buttons stopped working
jesper
I have a problem with my empeg Mk 2 player.
Firmware: 3.00-alpha11
hijack 471
When I boot it, it seems ok, and everything shows ok on the screen, but after it go blank, and the little blue diode starts to blink, it won't react to anything, either pushing any of the buttons or using the remote. So I can't turn it on, neither in my car or at home.
When I put the usb cable in a computer, the computer finds the
device, and it's possible to install the usb driver, but emplode
doesn't find it.
Any idea what the problem could be and if there's something I could do myself to fix it?
#312866 - 11/08/2008 16:26 Re: Buttons stopped working [Re: jesper]
Post a serial log.
#312883 - 12/08/2008 03:14 Re: Buttons stopped working [Re: Roger]
jesper
Here's the serial log when I boot, I guess you where meaning this:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v471 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Apr 27 21:31:57 EDT 2007
Processor: Intel StrongARM-1100 re
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102736) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
show_message("Hijack v471 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005e80).
empeg RDS driver initialised
RAM disk driver initialized: 16 RAM disks o
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
hda: IBM-DJSA-210, ATA DISK drive
ide_data_test: wrote 0x5555 read 0x5555
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:b
0
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
Timezone: Atlantic/South_Georgia
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
#316743 - 28/11/2008 09:10 Re: Buttons stopped working [Re: jesper]
spag
My empeg shows exactly the same behaviour.
Boot-Log:
speak now,
e000 v1.04
Copying kernel...
the kernel.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v479 ([email protected]) (gcc
version 2.95.3 20010315 (release)) #2 Tue Sep 4 09:18:20 EDT 2007
empeg-car player (hardware revision 9, serial number 120001072) 16MB DRAM
Signature is 67706d65 'empg'
Found custom animation at offset 0x99b78
show_message("Hijack v479 by Mark Lord")
empeg state support initialised 0089/88c1 (save to d0004700).
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xab80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xffbf
ide_data_test: wrote 0xffff read 0xffbf
ide_data_test: wrote 0xaaaa read 0xffbf
ide_data_test: wrote 0x5555 read 0xffbf
hda: TOSHIBA MK6021GAS, ATA DISK drive
hda: TOSHIBA MK6021GAS, 57231MB w/0kB Cache, CHS=7296/255/63
00:02:d7:18:04:30
Partition check:
Mounting proc
Comply...
Starting player
Timezone: CET
Using non-standard cache size 90 (bonus 0Mb, adjustment 10)
Vcb: 0x4069a000
Thanks, Peter
#316745 - 28/11/2008 09:31 Re: Buttons stopped working [Re: spag]
spag
CTRL-C the player and restarting it without playlist ("player -i") on the serial console seems to help.
Thanks, Peter.
#316768 - 29/11/2008 04:26 Re: Buttons stopped working [Re: spag]
Check for a pinched displayboard ribbon cable.
#321429 - 15/04/2009 14:52 Re: Buttons stopped working [Re: spag]
jesper
Thanks, Peter.
Well, it worked for me too!
What does it do, and what was the problem to begin with??
Everything seems normal now?
Great!
#321430 - 15/04/2009 15:19 Re: Buttons stopped working [Re: jesper]
Well, it worked for me too! What does it do, and what was the problem to begin with??
If player -i fixed your problem, then it means the player was frozen because it was trying to play a corrupted MP3 file, and it's liable to freeze again the next time it hits that file. If you can find out which file it is, you should delete it.
#321451 - 16/04/2009 02:33 Re: Buttons stopped working [Re: tfabris]
Doesn't necessarily have to be an mp3 file. I've forgotten how it did it but one time I managed to load something that wasn't an mp3. Didn't even have .mp3 in the file name, but it stopped the player cold.
