#317564 - 28/12/2008 13:54 SSD upgrade woes...
Major_Sarcasm
Loc: Isle of Wight, UK
Hi All
My long-suffering spouse bought me a couple of Transcend 32GB SSDs for Christmas as linked in the CF Empeg thread here.
I installed them yesterday and used Mark's Big Disk Builder as per the drive upgrade instructions in the FAQ (very comprehensive, thanks Tony). The builder worked fine, no problems that I could see so I installed V3A11 with Hijack slipstreamed downloaded from Mark's Big Disk page. So far so good. After installation, I updated Hijack to 503 and then tried to upload some files with Emplode. For some odd reason, Emplode couldn't see the Empeg on COM1, even though I'd been uploading Hijack with COM1 only a few minutes previously. No probs, I thought, I'll edit config.ini to reflect the static IP that I wanted on the 'peg which was the only reason that I wanted to use COM1 to connect anyway.
So, I ended up with an Empeg with V3A11 and Hijack 503 connected via Emplode on the IP I required. Great! Until I asked it to have some music on it.
I added just over a GB of files to Emplode and hit sync. I wandered off (as you do) and came back a bit later. The first thing I noticed was the message on the Empeg's display: "0000.-1 hdb: err: stat_timo" Not having seen that before, I opened my Terminal client (Tera Term) and watched the serial output (sorry, don't have a record). By this time, Emplode had popped up some warnings about files not being uploaded.
I killed the Emplode process as it seemed to be stuck and going nowhere and made the decision to re-build the disks (I'd also remembered a bug in A11 that used to cause me grief and was the reason that I wasn't running it prior to the new HDDs) with V2.0 final instead. I deleted the fids and did this, still using Mark's Big Disk builder, but using V2.0 Final without Hijack this time, adding 503 afterwards.
All went without a hitch and I was able to access COM1 again from within Emplode. Not sure what the problem with A11 and the COM access is, but never mind.
I tried uploading some songs again and got the same issues only worse. Log below.
end_request: I/O error, dev 03:44 (hdb), sector 553676
hdb: drive not ready for command
hdb: stat_timo: status=0xff
show_message("0000.-1 hdb: err: stat_timo")
ide0: reset: success
end_request: I/O error, dev 03:44 (hdb), sector 553678
end_request: I/O error, dev 03:44 (hdb), sector 553680
end_request: I/O error, dev 03:44 (hdb), sector 553682
end_request: I/O error, dev 03:44 (hdb), sector 553684
end_request: I/O error, dev 03:44 (hdb), sector 553686
*****CUT TO SAVE SPACE (100s OF LINES)*****
end_request: I/O error, dev 03:44 (hdb), sector 33106
Restored terminal settings
Restart code received
Starting player
Timezone: GMT
  player.cpp        : 385:empeg-car 2.00 2003/04/01.
end_request: I/O error, dev 03:44 (hdb), sector 264
! tunedb_disk.cpp   :1274:Database size mismatch error.
Vcb: 0x4086d000
*****AT THIS POINT EMPLODE/EMPEG GOT STUCK AND REQUIRED A HARD RESET*****
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v503 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Aug 14 22:07:32 EDT 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102438) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb84
Tuner: loopback=1, ID=-1
show_message("Hijack v503 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffaa
ide_data_test: wrote 0x5555 read 0x5f55
hda: TS32GSSD25-M, ATA DISK drive
hdb: TS32GSSD25-M, ATA DISK drive
hda: TS32GSSD25-M, 30560MB w/0kB Cache, CHS=62090/16/63
hdb: TS32GSSD25-M, 30560MB w/0kB Cache, CHS=62090/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:86
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg init 0.8
Mounting proc
Starting player
Timezone: GMT
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
Vcb: 0x4086d000
Dead temp.sensor, status=0x00
I checked the Empeg and only the 1st layer of my playlists had been added but no files. The bizarre thing about all this is that I don't think either of the SSDs is faulty. The builder worked ok and the player software installed without any problems. I tried running smartctl, but error logging is not supported by these drives (so smartctl said).
Any clues, clever friends? Should I try the regular disk builders on the drives individually and run the stress tests? Would this be safe on SSDs?
Steve
#317565 - 28/12/2008 14:12 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
Thought I'd try Jemplode quickly to see if it handled things any differently. I asked it to delete the playlists that had already been uploaded.
hda: stat_timo: status=0xd0
show_message("0120.-1 hda: err: stat_timo")
hda: no DRQ after issuing WRITE
hdb: stat_timo: status=0xd0
show_message("0120.-1 hdb: err: stat_timo")
hdb: no DRQ after issuing WRITE
Restarting system.
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0004a00).
ide_data_test: wrote 0xaaaa read 0xbfaa
Partition check:
Mounting proc
Starting player
Timezone: GMT
Vcb: 0x4086d000
It removed them ok, but there was a lot of garbage at the start.
Steve
#317581 - 28/12/2008 20:04 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Maybe the SSD firmware has a master/slave bug (or maybe they're not jumpered correctly?).
So, for fun, remove one SSD, and rebuild from scratch. Any better?
#317592 - 29/12/2008 07:24 Re: SSD upgrade woes... [Re: mlord]
Major_Sarcasm
Well, I've searched Transcend's website for firmware updates but with no joy. Just going to try individual builds now. Post back a little later.
Steve
#317593 - 29/12/2008 07:49 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
I've checked the jumper positions. Based on the label on the drive...
I would say that the positions are correct? One jumper for master, no jumper for slave.
When I had the empeg booted up yesterday with both drives in, she was happy to report both drives present and correct.
Steve
#317594 - 29/12/2008 10:01 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
OK, left the drive that was jumpered as master connected and rebuilt that. Just tried uploading two albums to it and got:
Adding Swap: 16596k swap-space (priority -3)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
show_message("0740.-1 hda: err: stat_timo")
No secondary hard disk
Starting player
Timezone: GMT
Vcb: 0x4086d000
So, two timeout errors in about 25 songs. Not good. Just for shits and giggles, I deleted the songs and uploaded them again. This time I got three errors. In both upload attempts, the files were transferred successfully to the empeg, despite the errors, with no warnings from emplode. When I tried yesterday to upload significantly more music, emplode displayed errors and some tracks were not transferred.
Gonna do the same with the slave (jumpering it as master).
Steve
#317595 - 29/12/2008 10:26 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
right in the middle of building the second drive and I've noticed something curious. The 'pumping partition' stage of the builder wizard was subject to long pauses in the progress bar during the building of the first drive, whereas the second drive was not and the partition was pumped in about 1/4 of the time. Not sure if it's relevant.
Steve
#317596 - 29/12/2008 11:11 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
Build of second drive done, going to install player software and hijack. Thought I'd post the log.
e000 v1.04
Copying kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
show_message("Hijack v488 by Mark Lord")
empeg state support initialised 0089/88c1 (save to d0005080).
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0x5555 read 0xff55
Partition check:
Trying to unmount old root ... Freeing unused kernel memory: 4k init+ /bin/mount -n /proc
+ log 'Builder image'
+ echo 'Builder image'
Buildeshow_message("Builder image")
r image
+ echo 'POPUP 9999 Builder image'
+ DRIVE1=
+ '[' -e /proc/ide/hdb -a -e /proc/ide/hdc ']'
+ '[' -e /proc/ide/hdb ']'
+ '[' -e /proc/ide/hdc ']'
+ /bin/mount -n -t ext2 -o ro,nocheck /dev/hda4 /drive0
+ '[' -d /drive0/fids ']'
+ /bin/umount /drive0
+ /bin/mkswap /dev/hda6
Setting up swapspace version 0, size = 16994304 bytes
+ /bin/swapon /dev/hda6
Adding Swap: 16596k swap-space (priority -1)
+ /bin/mkswap /dev/hda3
Setting up swapspace version 0, size = 17027072 bytes
+ /bin/swapon /dev/hda3
Adding Swap: 16628k swap-space (priority -2)
+ log 'Tuning hda5'
+ echo 'Tuning hda5'
Tuning show_message("Tuning hda5")
hda5
+ echo 'POPUP 9999 Tuning hda5'
+ /bin/tune2fs -c -1 -i0 /dev/hda5
tune2fs 1.17, 26-Oct-1999 for EXT2 FS 0.5b, 95/08/09
Setting maximal mount count to -1
Setting interval between check 0 seconds
+ makedrive hda4 /drive0
+ dev=/dev/hda4
+ log 'Making hda4 filesystem'
+ echo 'Makishow_message("Making hda4 filesystem")
ng hda4 filesystem'
+ echo 'POPUP 9999 Making hda4 filesystem'
+ /bin/mkfs.ext2 -v -s 1 -i 131072 -m 0 /dev/hda4
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
Linux ext2 filesystem format
Filesystem label=
243840 inodes, 31210200 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
Block size=1024 (log=0)
Fragment size=1024 (log=0)
3810 block groups
8192 blocks per group, 8192 fragments per group
64 inodes per group
Superblock backups stored on blocks:
        8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553,
        1024001, 1990657, 2809857, 5120001, 5971969, 17915905, 19668993,
        25600001,
Writing inode tables:  258/3810Dead temp.sensor, status=0x00
done
Writing superblocks and filesystem accounting information: done
+ log 'Tuning hda4'
+ echo 'Tuning hda4'
Tuning hda4
+ echo 'POPUP 9999 Tuning hda4'
show_message("Tuning hda4")
+ /bin/tune2fs -c -1 -i0 /dev/hda4
+ /bin/sync
+ /bin/sync
+ log 'Mounting hda4'
+ echo 'Mounting hda4'show_message("Mounting hda4")
Mounting hda4
+ echo 'POPUP 9999 Mounting hda4'
+ /bin/mount -n -o rw,nocheck /dev/hda4 /drive0
+ /bin/sync
+ /bin/sync
+ log 'Making directories'
+ echo 'Making dishow_message("Making directories")
rectories'
Making directories
+ echo 'POPUP 9999 Making directories'
+ /bin/mkdir /drive0/fids
+ /bin/mkdir /drive0/var
+ echo '[hijack]'
+ log 'Remounting ro'
+ echo 'Remountingshow_message("Remounting ro")
 ro'
Remounting ro
+ echo 'POPUP 9999 Remounting ro'
+ /bin/mount -n -o remount,ro /dev/hda4 /drive0
+ /bin/sync
+ /bin/sync
+ log 'hda4 completed'
+ echo 'hda4 completeshow_message("hda4 completed")
d'
hda4 completed
+ echo 'POPUP 9999 hda4 completed'
+ /bin/swapoff /dev/hda3
+ log 'Zeroing hda3'
+ echo 'Zeroing hda3'
Zeroing show_message("Zeroing hda3")
hda3
+ echo 'POPUP 9999 Zeroing hda3'
+ /bin/cat /dev/zero
/bin/cat: write error: No space left on device
+ /bin/swapoff /dev/hda6
+ log 'Done!  Testing disk..'
+ echo 'Done!  Testing disk..'
+ echo 'POPUP 9999 Done!  Testing disk..'
show_message("Done!  Testing disk..")
+ /sbin/hdstress
hdstress.cpp   189 (   33): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Stressing /dev/hda: Spinning up.
Speed checking /dev/hda3
Read/write of 8Mb took 9.65 seconds
Drive length is 62586880 blocks, seek testing
Seek test complete:  2.01 seconds.
hdstress.cpp   189 (   33): Poll result=1 on fd=5
hdstress.cpp   194 (   33): Read a button press
Read/write of 8Mb took 3.92 seconds
Seek test complete:  2.02 seconds.
Read/write of 8Mb took 6.78 seconds
Read/write of 8Mb took 3.98 seconds
Tony, I thought it worth mentioning that this is Mark's Big Disk Builder. In the FAQ it states that this version doesn't stress test the drives after build when in fact it does.
Steve
#317597 - 29/12/2008 11:42 Re: SSD upgrade woes... [Re: Major_Sarcasm]
I was told bigdisk didn't stress. Who told me that?
#317599 - 29/12/2008 11:48 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
Bugger. The second drive displayed five errors whilst uploading the same songs.
Any clues Mark? Could it be that these devices simply aren't compatible with the Empeg full stop?
Steve
#317600 - 29/12/2008 11:51 Re: SSD upgrade woes... [Re: tfabris]
It doesn't do that in my latest internal copy here
(I just checked it now), but it might (or apparently does)
in some of the released versions.
That thing really needs an update soon-ish,
but my MythTV box is calling for some TLC and VDPAU goodness.
#317601 - 29/12/2008 11:56 Re: SSD upgrade woes... [Re: Major_Sarcasm]
That does appear to be the case -- the original thread showed
64GB devices working, but perhaps these 32GB ones still have
firmware bugs, or are very slow at writing small amounts of data.
Try hdparm -W0 -K1 (top link on Hijack page)
on them (once), and then send them some more tunes.
EDIT: actually, first dump/post here the hdparm -I results.
Edited by mlord (29/12/2008 11:57)
#317602 - 29/12/2008 12:05 Re: SSD upgrade woes... [Re: mlord]
Oh, and I wouldn't panic too much just yet.
There's this guy around here somewhere who knows how
to hack IDE stuff at the lowest of levels, so odds
are good that these can be made to work just fine. smile
A longer than normal timeout in the Linux driver
might cure that one. Spec says 20msec, Linux waits 50msec.
But we could easily have it wait (much) longer, if it turns
out to be simply slow at write-prepare/erase time.
Another thing which will probably help a great deal
for SSD here (including CF cards), would be to turn on
the multi-sector write capabilities, if they're not already on.
Hijack used to do this, but I think (not sure) that I took
it out again after a complaint from somewhere.
This really should go back in for CF cards and SSDs.
Edited by mlord (29/12/2008 12:07)
#317603 - 29/12/2008 12:24 Re: SSD upgrade woes... [Re: mlord]
Major_Sarcasm
Hehe, that's why I'm grateful & glad you're on the case.
Being a complete linux n00b, can you tell me why when I try to execute the hdparm file, I get this:
**edited for brevity of the thread**
It seems to be ignoring the -I switch.
Edited by Major_Sarcasm (29/12/2008 12:59)
Edit Reason: thread's getting very cumbersome
Steve
#317604 - 29/12/2008 12:48 Re: SSD upgrade woes... [Re: Major_Sarcasm]
You need to tell it what drive to look at.
So try :
hdparm.bin -I /dev/hda
hdparm.bin -I /dev/hdb
Edited by LittleBlueThing (29/12/2008 12:49)
#317605 - 29/12/2008 12:55 Re: SSD upgrade woes... [Re: LittleBlueThing]
Major_Sarcasm
Ah ha! Thank you indeed.
empeg:/drive0/var# ./hdparm.bin -I /dev/hda
/dev/hda:
ATA device, with non-removable media
        Model Number:       TS32GSSD25-M
        Serial Number:      00238605014A
        Firmware Revision:  V0826
Standards:
        Used: ATA/ATAPI-7 T13 1532D revision 4a
        Supported: 8 7 6 5 & some of 8
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:   62586880
        device size with M = 1024*1024:       30560 MBytes
        device size with M = 1000*1000:       32044 MBytes (32 GB)
Capabilities:
        LBA, IORDY(can be disabled)
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 1   Current = ?
        Recommended acoustic management value: 128, current value: 254
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
           *    Power Management feature set
                Write cache
                Look-ahead
           *    Mandatory FLUSH_CACHE
           *    SATA-I signaling speed (1.5Gb/s)
           *    SATA-II signaling speed (3.0Gb/s)
Security:
        Master password revision code = 65534
                supported
        not     enabled
        not     locked
        not     frozen
        not     expired: security count
        not     supported: enhanced erase
        2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Integrity word not set (found 0x0000, expected 0xa8a5)
Steve
#317607 - 29/12/2008 13:46 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Okay, so was that before, or after, you did hdparm -W0 -K1 ?
If it was before, then you should instead try hdparm -W1 -K1
#317608 - 29/12/2008 13:47 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
Added the 1st drive back in and hdparm'd it. Exactly the same (as expected) just a different serial no.
It appears that "hdparm.bin -I /dev/hda" works but "hdparm.bin -I /dev/hdb" doesn't when two devices are connected. I'll have to manually swap each drive into the master position to effect any changes it seems.
I haven't done this yet as your post appeared to suggest holding off on these commands until I'd posted the results of "-I"
Steve
#317609 - 29/12/2008 13:48 Re: SSD upgrade woes... [Re: mlord]
Oh.. and I now see that these are SATA SSDs.
Which cannot work as-is in an empeg (wrong connector, among other issues).
So.. how do you have them connected ?
EDIT: Mmm.. I suppose the maker might have built-in
a SATA-to-IDE convertor chip, which could explain that.
And those chips often cause other problems, too.
Thx.
Edited by mlord (29/12/2008 13:51)
#317610 - 29/12/2008 13:54 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Uh.. you'll need to fix that before wasting time on *anything* else here.
This is fundamental, and must work.
Edited by mlord (29/12/2008 13:55)
#317611 - 29/12/2008 14:04 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
empeg:/drive0/var# ./hdparm.bin -W1 -K1 /dev/hda
/dev/hda:
 setting drive keep features to 1 (on)
 setting drive write-caching to 1 (on)
 write-caching =  1 (on)
Just uploaded some files and got:
show_message("0000.-1 hda: err: stat_timo")
Steve
#317612 - 29/12/2008 14:05 Re: SSD upgrade woes... [Re: mlord]
Okay, so the bridge chip is indeed built-in,
according to page 6 of the product datasheet.
So one might reasonably expect these things to actually be IDE (ATA) compliant. heh.
#317613 - 29/12/2008 14:10 Re: SSD upgrade woes... [Re: Major_Sarcasm]
The dual drive hdparm thing is one issue,
but I suppose we should set that aside
and concentrate on getting a single drive config going first.
So unplug one drive, and use just a single SSD for now.
Here's a special hijack image that waits longer for DRQ on writes.
The theory is that they're pre-erasing the sectors before
allowing the data transfer to begin, and this is taking a
while. Especially when our transfers are so tiny, requiring
lots of erasing and data shuffling internal to the SSD.
Edited by mlord (29/12/2008 14:12)
#317614 - 29/12/2008 14:11 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
I've just done a "hdparm -I" and the write cache is now got an asterisk by it, so I guess that flag stuck.
The drives have a 44 pin connector and plug straight in. I noticed the SATA reference in the data earlier and wondered whether it would have significance to this app.
Steve
#317615 - 29/12/2008 14:12 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
Just hijacking now. Report back soon.
Steve
#317616 - 29/12/2008 14:18 Re: SSD upgrade woes... [Re: Major_Sarcasm]
It's just an ordinary (but misnamed) zImage file, same as usual.
#317620 - 29/12/2008 14:55 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
*faints*
OK, just uploaded the same bunch of files (about 25) with no errors being reported via serial and none on the empeg's display either.
Mr Lord, I bow before thee.
Should I apply those W1 K1 switches to the other drive?
Steve
#317626 - 29/12/2008 16:06 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Well, first we need to know if the -W1 -K1 did it, or if the new hijack did it..
Did you try the -W1 -K1 with the original (released) Hijack ?
#317627 - 29/12/2008 16:08 Re: SSD upgrade woes... [Re: mlord]
Or more useful, perhaps, could you just do hdparm -W0 and then try some more uploads with the experimental hijack ?
If that still works, then I'll release that copy of Hijack, and *maybe* respin the bigdisk images to include it.
#317628 - 29/12/2008 16:25 Re: SSD upgrade woes... [Re: mlord]
Major_Sarcasm
Yes, and that resulted in errors.
Will do. I'll report back in a bit.
Steve
#317629 - 29/12/2008 16:40 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Major_Sarcasm
OK, W set to zero and uploaded tracks with no errors. I guess that means that your modified hijack is what fixed the problem.
Just out of interest, will enabling/disabling write-caching have any performance benefits/detriments in this environment?
Do you have any idea why I was unable to use /dev/hdb to specify the slave SSD with hdparm?
Steve
#317634 - 30/12/2008 02:23 Re: SSD upgrade woes... [Re: Major_Sarcasm]
fixed the problem.
Great. I'll make it an "official" release shortly.
I think I'd suggest disabling it, as our kernel doesn't know
anything about safely flushing the write cache, and
(contrary to common opinion) the empeg s/w *does*
write to the media (dynamic data partition)
during normal playback operation.
So just leave write-caching
off for safety with these slow-writing SSDs.
For regular hard disks, no issues either way.
No. But that *has to work* if you want a two-drive system.
I'm probably just missing something obvious..
Edited by mlord (30/12/2008 02:25)
#317635 - 30/12/2008 02:40 Re: SSD upgrade woes... [Re: mlord]
Or maybe not. Sourceforge seems to have finally broken my scripts,
and removed the ability to easily upload binary files.
I refuse to use their absolutely STUPID "file release manager"
crap for Hijack, so this might be the end of Hijack availability
at Sourceforge
Hmmph.
EDIT: hacked it, working again. For now.
Edited by mlord (30/12/2008 11:44)
#317638 - 30/12/2008 03:28 Re: SSD upgrade woes... [Re: mlord]
I've also updated the bigdisk builder stuff on my server,
to include Hijack v504 in the images. Untested, of course. smile
#317642 - 30/12/2008 11:29 Re: SSD upgrade woes... [Re: mlord]
Major_Sarcasm
I added the second drive back in late last night and uploaded ~27GB of files with no problems whatsoever. I had a look in the fids folders on each drive and it seems to be balancing the files between the two.
Mark, as ever, I am most grateful for your assistance.
Steve
#317648 - 30/12/2008 16:34 Re: SSD upgrade woes... [Re: mlord]
Mark, you are awesome.
#318440 - 25/01/2009 04:57 Re: SSD upgrade woes... [Re: tfabris]
101
Loc: US
I am using v504 disk builder image with a single 64 GB SSD of the same brand and getting a ton of these virtual memory errors:
VM: do_try_to_free_pages failed for mkfs.ext2...
show_message("1530.-1 nomem err")
This is on an old 12MB player, any ideas why?
#080000512 green 12GB
#318441 - 25/01/2009 12:15 Re: SSD upgrade woes... [Re: 101]
Which exact builder file are you using (name and bytecount, please)?
Can you capture a trace from the serial port while running it (helps a LOT)?
Thanks.
#318442 - 25/01/2009 13:55 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
builder_bigdisk_v3.upgrade
2.16 MB (2,267,745 bytes)
MD5 0b8b1f793a7e2a7e8253fad6a35afc41
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v504 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Mon Dec 29 23:29:04 EST 2008
c0c00000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 7, serial number 80000512) 12MB DRAM
Command line: mem=12m
Memory: 10944k/12M available (996k code, 20k reserved, 324k data, 4k init)
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v504 by Mark Lord")
empeg state support initialised 0089/88c1 (save to d0005000).
hda: TS64GSSD25-M, ATA DISK drive
hda: TS64GSSD25-M, 61136MB w/0kB Cache, CHS=7793/255/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:02:0
0
Partition check:
Builder image
+ echo 'POPUP show_message("Builder image")
9999 Builder image'
+ DRIVE1=
Setting up swapspace version 0, size = 16412672 bytes
Adding Swap: 16028k swap-space (priority -1)
Setting up swapspace version 0, size = 24670208 bytes
Adding Swap: 24092k swap-space (priority -2)
+ log 'Tuning hda5'
Tuning hda5show_message("Tuning hda5")
+ dev=/dev/hda4
ng hda4 filesystem'
hda4 is mounted.
Filesystem label=
488256 inodes, 62492850 blocks
First data block=1
7629 block groups
64 inodes per group
        25600001, 53747713,
Writing inode tables: done
Writing superblocks and filesystem accounting information: show_message("1530.-1
 nomem err")
#318443 - 25/01/2009 16:09 Re: SSD upgrade woes... [Re: 101]
Mmm.. looks like you are doing everything The Right Way(tm).
So, the mkfs thinks it is running out of memory,
which is very odd given the amount of swap space
we allocate for its use.
If I can find my 32GB CF card, I'll give this a try
on that later today in a Mk2 12MB unit. And then perhaps
again with a larger hard disk.
Edited by mlord (25/01/2009 16:17)
#318444 - 25/01/2009 16:18 Re: SSD upgrade woes... [Re: mlord]
If you grok Linux, you could just finish off the process by hand.
A reboot (from its present state) will give you a shell prompt
at the serial console, where you could re-issue the mkfs.ext2
command from the script by hand.
Edited by mlord (25/01/2009 16:19)
#318446 - 25/01/2009 22:32 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
I know enough to fumble around, but I couldn't figure out how to get a prompt on the builder image as every reboot attempts to reformat the drive. Seems like it would be pretty easy to work around if I could get to a prompt. Is that mkfs cmd the end of the script?
Thank you so much for such a ridiculously fast response btw, and I really appreciate the help.
#318447 - 25/01/2009 22:48 Re: SSD upgrade woes... [Re: 101]
Here's a builder version that logs you in, and tells you what to do.
Have fun. smile
Edited by mlord (25/01/2009 22:49)
#318448 - 26/01/2009 01:09 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
Thanks for that new image. However, when I manually run the first cmd (mkfs.ext2) I get the same nomem error.
#318449 - 26/01/2009 01:30 Re: SSD upgrade woes... [Re: 101]
Mmm.. bummer, but not completely unexpected.
I'm not sure why it fails to use the swap space for memory, but.. oh well.
Can you connect the drive to a Linux box (internally,
or externally via USB or whatever)
and just do the same commands to it from there?
That's the workaround at this point.
Edited by mlord (26/01/2009 01:31)
#318450 - 26/01/2009 01:41 Re: SSD upgrade woes... [Re: mlord]
I've scrounged up a Mk2 and a 60GB (hard) drive here now,
and we will see what happens with it.. gimme a few minutes..
Edited by mlord (26/01/2009 01:42)
#318451 - 26/01/2009 02:01 Re: SSD upgrade woes... [Re: mlord]
Mmm.. no problems here. But regardless, this might help:
builder_bigdisk_v3_alt.upgrade
This one has tweaked mkfs options to (hopefully) reduce the amount of RAM required.
Give it a whirl..
#318455 - 26/01/2009 12:12 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
The alt one you posted (link is a little squirrely)seems to have made it through the script. There was one error "zeroing hda3":
Not sure if that was normal or not, just sounds like it wrote to the end.
Do you think the problem is related to the empeg-flash driver? Seems like something is being loaded that is bigger than normal and causing an issue with this SSD on a 12MB player.
#318460 - 26/01/2009 13:32 Re: SSD upgrade woes... [Re: 101]
It doesn't mean flash as in SSD. There is a small amount of flash memory inside the empeg that stores some current state and config data.
#318461 - 26/01/2009 14:11 Re: SSD upgrade woes... [Re: 101]
Yes, that's normal. Ignore it.
No. Linux on the empeg doesn't even know you have an SSD.
It thinks of it and treats it exactly as a regular hard drive.
So, the _alt_ builder worked though, and you should now be all set.
#318466 - 26/01/2009 19:15 Re: SSD upgrade woes... [Re: mlord]
I've now updated the bigdisk builder images (at rtr.ca)
with Hijack v508. There's also now a new _v4_ builder
which uses a 4KB blocksize (rather than 1KB),
and a 4X higher bytes:inodes ratio.
These changes make it much more suitable for large disks
and/or low-memory usage.
Edited by mlord (26/01/2009 19:16)
#318474 - 26/01/2009 22:57 Re: SSD upgrade woes... [Re: mlord]
101
Loc: US
Thanks again so much for the help Mark, all seems to be working.
Only issues I have now are config related. I've been using the old 2.0 beta for like 7 years and I need to figure out how to get the fader back and now the player no longer shuts off in the car. So I'll need to do some searches to get up to speed on restoring that functionality, and what else is new.
SSD issues seem to be resolved.
#318526 - 27/01/2009 23:44 Re: SSD upgrade woes... [Re: 101]
101
Loc: US
Okay, I am completely baffled. I've done some searches and apparently I have "home mode in the car" syndrome and saw all these threads about a blown diode and HW replacement etc.
I will say that being a HW guy (encoder replacement was much more straight forward to me than swapping in an SSD) this is ridiculous. I put in my old drive with the old firmware and all functionality returned with 0 issues. Clearly this is a software problem, yet there's many threads on diode replacement and I couldn't find anything pointing to software.
What is the deal here? I have been out of the loop for years and just want to replace my dying mechanical HD with an SSD.
Can I just image my old drive to the SSD? At this point I could care less about losing a few gig to an LBA issue. I just want it to work with no hassle, as I don't have as much time to spend on this as I would like.
Suggestions? Please?
#318544 - 28/01/2009 13:05 Re: SSD upgrade woes... [Re: 101]
What is shown on the Hijack Menu's "Force AC/DC Power Mode"
screen on your player?
Post the four lines here, please.
#362525 - 10/09/2014 19:18 Re: SSD upgrade woes... [Re: Major_Sarcasm]
haffi
Loc: Iceland
Hi all I know this is an old thread but I am having similar problems...
I inserted a SSD 120GB Kingston SSD now into the Empeg with Adapter and It is getting the HDA timeout issues on the Display.
Can someone help me with this ? Is there a way to telnet into the empeg ? my Serial port does way to much of Crashing my computer ( since its a usb adapter ).
I used the Big disk Image first and then the hijack 5.18.
I am able to upload some tracks but it crashes the player all the time.
I have tried swapping out the SSD and the Adapter , plus the HDD cable with the same results.
Haf■ˇr Hilmarsson
CCIE VOICE #24527
Iceland.
#362526 - 10/09/2014 21:18 Re: SSD upgrade woes... [Re: Major_Sarcasm]
Yeah, my apologies for putting this on the back burner. Hijack has a telnetd built-in, which can be enabled by putting "ktelnetd_port=23" into the "[hijack]" section of the player's config.ini file.
For the adapter, I don't yet know what's wrong, and haven't made the time to investigate yet. But I have seem similar behaviour with some adapters in the past, and might still have one on hand that misbehaves like that. So.. there's hope.
With luck, it's just a timing thing: SSDs respond _instantly_ to stuff that takes milliseconds with mechanical drives, and something may just not be ready for that as soon as it ought to be.
#363920 - 02/05/2015 15:37 Re: SSD upgrade woes... [Re: Major_Sarcasm]
haffi
Loc: Iceland
Any new Mlord ? my player works ok... but if I try to fast forward and randomly it freezez up , and I think your right with the timing issues.
Where can I start.
If I telnet to the empeg and try fsck -fay /dev/hda4 it just says
empeg:/# fsck -fay /dev/hda4
fsck -fay /dev/hda4
Pass 1: Checking inodes, blocks, and sizes
Error allocating block bitmap (1): Memory allocation failed
Parallelizing fsck version 1.19 (13-Jul-2000)
my
empeg:/# hdparm -I /dev/hda
hdparm -I /dev/hda
/dev/hda:
Model Number: KINGSTON SVP200S3120G
Serial Number: 50026B72270195F5
Firmware Revision: 501ABBF0
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5
Standards:
Used: unknown (minor revision code 0x0110)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
heads 16 16
sectors/track 63 63
LBA user addressable sectors: 234441648
LBA48 user addressable sectors: 234441648
device size with M = 1024*1024: 114473 MBytes
device size with M = 1000*1000: 120034 MBytes (120 GB)
Capabilities:
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: 254
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5 udma6
Commands/features:
Enabled Supported:
* SMART feature set
* Write cache
Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
* 48-bit Address feature set
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
Write-Read-Verify feature set
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* SMART Command Transport (SCT) feature set
Security:
supported
not enabled
not locked
not frozen
Logical Unit WWN Device Identifier: 50026b72270195f5
NAA : 5
IEEE OUI : 26b7
Unique ID : 2270195f5
Integrity word not set (found 0x0000, expected 0x6ea5)
Haf■ˇr Hilmarsson
CCIE VOICE #24527
Iceland.
#363921 - 03/05/2015 07:11 Re: SSD upgrade woes... [Re: Major_Sarcasm]
haffi
Loc: Iceland
Player displays this and then the empeg is non responsive
0000.0 hda: err: stat_timo
Haf■ˇr Hilmarsson
CCIE VOICE #24527
Iceland.
#363922 - 03/05/2015 13:25 Re: SSD upgrade woes... [Re: Major_Sarcasm]
When that message appears on the display, there will be a corresponding, more detailed message at the serial port.
Something like: hda: stat_timo: status=0x80
followed by another line describing what it was trying to do at the time.
Any chance you could capture those messages and post them here?
Based on the value it prints for "status=0x..", it might be possible to work around the issue.
In particular, if it says "status=0x88", and "no DRQ after issuing WRITE", then it's a very easy fix.
Thanks.
Edited by mlord (03/05/2015 13:33)
#363923 - 03/05/2015 13:41 Re: SSD upgrade woes... [Re: haffi]
fsck -fay /dev/hda4
To work around that problem with fsck, just do "swapon -a" before starting the fsck command.
Edited by mlord (03/05/2015 13:42)
