#323695 - 25/06/2009 00:10 R/C glider going 392mph
On YouTube That's scary fast considering how close by the passes are going.
Edit: Corrected link.
Edited by gbeer (25/06/2009 00:12)
#323700 - 25/06/2009 01:00 Re: R/C glider going 392mph [Re: gbeer]
I think if you got hit in the head by a 200mph glider you'd still feel the hurt. wink
Have you seen the flash animation one of the DS guys did explaining how they get them going that fast?
#323710 - 25/06/2009 03:56 Re: R/C glider going 392mph [Re: gbeer]
Holy cow, I didn't even know that was possible.
http://en.wikipedia.org/wiki/Dynamic_soaring
I wonder if a variant on this technique could be employed as a generator. Instead of a static turbine sitting on the top ridge of a hill, some sort of larger angled turbine system whose blades shift position as they dip into the wind shadow behind the hill. You could generate serious energy like that.
#323722 - 25/06/2009 12:30 Re: R/C glider going 392mph [Re: tfabris]
I haven't been able to stop thinking about this exact topic since I first saw the demo yesterday afternoon. smile
#323723 - 25/06/2009 12:40 Re: R/C glider going 392mph [Re: hybrid8]
If you've got that much difference between your fast airstream and your slow airstream, just stick a normal wind turbine in the fast airstream. Dynamic soaring is neat because it extracts some energy without a ground anchor, not because it extracts more energy than a system with a ground anchor.
#323724 - 25/06/2009 12:57 Re: R/C glider going 392mph [Re: hybrid8]
#323728 - 25/06/2009 17:13 Re: R/C glider going 392mph [Re: peter]
So you're saying that a simple turbine in the fast airstream couldn't be made to spin any faster by taking advantage of the dynamic soaring technique?
#323729 - 25/06/2009 17:27 Re: R/C glider going 392mph [Re: tfabris]
The way I understood the flash animation, it made it seem like the benefit of hitting both airstreams was such that the plane in effect always had a tail wind and it was almost as if it was always on a downward trajectory, picking up more speed every time it goes around (up to a point of course).
The wind coming over the ridge of the hill for the record-breaker was only just over 45MPH I believe.
#323787 - 26/06/2009 14:30 Re: R/C glider going 392mph [Re: tfabris]
Yes. I was going to say, "Yes, obviously", but in fact it got less obvious the more I thought about it. But I think the answer is, that you can only extract energy from relative speed, not absolute speed. Unless the shape of the hill is such that the lee air isn't just stagnant, it's bodily flowing in the opposite direction, then you can extract more energy from a ground-mounted turbine fed from the speed of the air relative to the ground, than you can from any flight manoeuvre which relies on the speed of some air relative to some other air. Dynamic soaring is like a gearbox: it can convert a low-speed, high-torque input into a high-speed, low-torque output, but it doesn't actually give you any more power.
Dynamo generators are more efficient at high speed than at low speed, but that's dealt with in real wind turbines by having an actual physical gearbox between the blades and the dynamo.
#323798 - 26/06/2009 17:07 Re: R/C glider going 392mph [Re: peter]
Ah, that makes sense.
