#346332 - 11/07/2011 02:01 CSV, XML jEmplode output direct from mp3tofid
Daria
Loc: Somerville, MA
https://github.com/empeg/mp3tofid/tree/macos
adds options --jemplode-csv-filename= and
--jemplode-xml-filename=
both take a path.
#346490 - 18/07/2011 23:12 Re: CSV, XML jEmplode output direct from mp3tofid [Re: Daria]
pim
Not being familiar with jemplode, can you explain what these files are for?
Thanks,
Pim
#346495 - 19/07/2011 09:50 Re: CSV, XML jEmplode output direct from mp3tofid [Re: pim]
Daria
Loc: Somerville, MA
well, Palantir uses the CSV so you can load the database into it and use it to build playlists on the fly. My goal is to use either the CSV or the XML to do the same for an iPhone client.
#346496 - 19/07/2011 14:04 Re: CSV, XML jEmplode output direct from mp3tofid [Re: Daria]
pim
So these files are not really related to Jemplode other than that they can be built from Jemplode?
Thanks,
Pim
#346499 - 19/07/2011 15:50 Re: CSV, XML jEmplode output direct from mp3tofid [Re: pim]
Daria
Loc: Somerville, MA
apparently one of the formats was also built by emptool or emplode, the other 2 formats are built by jemplode only. beyond that, nothing special about jemplode. whatever can use them.
