#363392 - 06/02/2015 05:10 empeg resurrection
redmosquito
I got my 12-13 years ago (maybe even longer ago). Used it for years and recently the hard drive failed I can't believe it lasted this long. I haven't done anything except use it in my car for years. Well I bought a new SSD hard drive and of course I have a newer computer than what I used to have a few years ago. I'm trying to set everything up but I'm lost. Emplode won't install since I'm running Window 7 pro on a 64 bit machine. I got a usb to serial adapter so I can get the hard drive going. Can someone point me in the right direction or let me know what I need to do? Thanks.
#363393 - 06/02/2015 06:17 Re: empeg resurrection [Re: redmosquito]
It ought to. I just installed car-emplode-v2.00 on Windows 8.1 Pro on a 64-bit machine. What error message do you get?
It even discovered and connected to my spare empeg over Ethernet (well, the laptop is on Wifi, but...). I suspect that USB won't work, though.
#363394 - 06/02/2015 12:28 Re: empeg resurrection [Re: redmosquito]
Use ethernet rather than USB with emplode.
#363398 - 07/02/2015 04:33 Re: empeg resurrection [Re: redmosquito]
redmosquito
Okay, I was initially using my original cd to install Emplode, which appears to have been the problem. car-emplode-v2.00 worked.
Unfortunately, Emplode won't detect my empeg. I've tried usb, ethernet, serial (via usb). It just searches. Any suggestions?
Thanks again.
#363399 - 07/02/2015 06:18 Re: empeg resurrection [Re: redmosquito]
StigOE
When using ethernet, check what IP address the empeg has and what the IP address on your machine is. They need to be on the same network segment.
#363400 - 07/02/2015 15:13 Re: empeg resurrection [Re: StigOE]
redmosquito
The Empeg is not fully booting up. So I can't access the menus on it to get an ip address from it.
#363401 - 07/02/2015 15:53 Re: empeg resurrection [Re: redmosquito]
StigOE
Then you need to get a boot log from the serial port so that the experts can see where it stops and hopefully guide you further.
#363403 - 07/02/2015 16:38 Re: empeg resurrection [Re: StigOE]
redmosquito
How do I get a boot log if I can't connect to the Empeg?
Thanks for the help guys. I appreciate it.
#363404 - 07/02/2015 18:40 Re: empeg resurrection [Re: redmosquito]
#363405 - 07/02/2015 22:06 Re: empeg resurrection [Re: andy]
redmosquito
Andy thanks for the link.
Below is the output. The last line says Kernal panic: VFS: Unable to mount root fs on 03:05.
After doing a search, I saw this post about that. Will this SSD not work?
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v334 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Apr 26 10:31:47 EDT 2003
empeg-car player (hardware revision 9, serial number 30102262)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9a790
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TS128GPSD330, ATA DISK drive
hda: TS128GPSD330, 122105MB w/1kB Cache, CHS=15566/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:d
6
Partition check:
hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
#363406 - 08/02/2015 03:39 Re: empeg resurrection [Re: redmosquito]
StigOE
So this is a brand new disk and you've basically just tried to boot up the empeg to put some music onto it? If so, you need to first build the file structure on the disk before it will boot up and you can use emplode. To learn how to do that, head over to Rio Car Disk Upgrade Guide. You also need to download the disk builder software.
#363412 - 08/02/2015 23:00 Re: empeg resurrection [Re: redmosquito]
redmosquito
Okay, I've got it working. I now have 128gb SSD installed and working.
The original issue was the USB to serial adapter I was first using. I got a FTDI one and it worked.
Thanks StigOE for posting the link to the big disk builder. When you did, I was just getting ready to go look for it last night.
Thanks again everyone for the help and posting up helpful information and links to make this easier.
#363422 - 09/02/2015 15:19 Re: empeg resurrection [Re: redmosquito]
I purchased one of these cables for my Empeg. While it's a bit pricey, it has the FTDI serial adapter and null modem all in one cable. Just plug it in, install the driver and it works. No other fiddly adapters or bits strung together.
