#38288 - 09/09/2001 14:38 Tuner Specs?
jwickis
Loc: India
The manual says it uses a fuzzy logic autotuning, RDS & RBDS capable & the FM tuning range. Does anyone know what other specs the tuner has? i.e. sensitivity, signal/noise, etc.?
#695-Mk2/8 colors-12Gig/TUNER-but awaits v2.x & VR
"No buyers regret"
#38289 - 10/09/2001 02:29 Re: Tuner Specs? [Re: jwickis]
Not that I can find any specs that are in the same language/units as any other tuner I can find, but:
FM:
Sensitivity typ 1.4uV (test conditions 30db S+N/N)
S+N/N typ 64dB
THD+N typ 0.07%
Adjacent channel selectivity 90dB (test conditions distance +-200kHz, audio -30dB, ref=audio at rd input=17dBuV)
AM:
Sensitivity typ 4.0uV (test conditions: 10dB S+N/N)
S+N/N: typ 50dB (f=1000Hz)
THD+N: typ 0.35%
If you're interested, the datasheet is available at http://www.microtune.com/products/1384_Series.html
#38290 - 10/09/2001 09:08 Re: Tuner Specs? [Re: altman]
flashman
Loc: U.S.
I noticed from the features list that "Weather band optional" was listed.
Is it possible that this is avalible with a software upgrade??
Just curious.
12Gb MKII 080000516 Blue
12Gb MKII 080000516 Blue 20Gb MKII 010101303 Green 20Gb MKII 090001020 Green 30Gb MKII 10101980 Blue
#38291 - 10/09/2001 10:40 Re: Tuner Specs? [Re: flashman]
Officially, the tuners are all non-weatherband ones (this is what we ordered); in actual fact, some of them *are* weatherband capable (they had stock they wanted to shift).
There's no official support for weatherband, though.
#38292 - 10/09/2001 15:42 Re: Tuner Specs? [Re: altman]
jwickis
Loc: India
Thank You Hugo, this is what, more or less, I was looking for.
I don't suppose there's a way to tell which modules are WX capable?
#695-Mk2/8 colors-12Gig/TUNER- awaits v2.x & Voice Recog.
#38293 - 10/09/2001 23:45 Re: Tuner Specs? [Re: jwickis]
There is, yes. Electronically, we can check the calibration values for weatherband - if they're present, it's a weatherband unit.
The other way is to open the black box (though there are no warranty stickers, I wouldn't recommend this method obviously). The weatherband module has a red label on the top, the normal one has a green label.
#38294 - 11/09/2001 01:28 Re: Tuner Specs? [Re: altman]
_hardcore_
Loc: Copenhagen, Denmark
Out of curiosity, what is weather band ?
\\Kaare
#38295 - 11/09/2001 01:51 Re: Tuner Specs? [Re: _hardcore_]
It's FM at 162.4MHz-162.55MHz, has emergency weather warnings and so on. Only in the USA though, I believe. I'm sure someone else here knows more!
#38296 - 11/09/2001 03:36 Re: Tuner Specs? [Re: _hardcore_]
tms13
Loc: Lochcarron and Edinburgh
A quick Google turned up <URL:http://www.srh.noaa.gov/tbw/nwr/>.
I believe that RDS supports a similar feature (though my home stereo only supports interruption/wakeup for TA, News and Info programming - I'm not sure that Weather is a separate category).
More at <URL:http://www.nws.noaa.gov/nwr/>.
Toby Speight - 040103385
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#38297 - 11/09/2001 08:49 Re: Tuner Specs? [Re: tms13]
_hardcore_
Ok. If its an American feature, perhaps that why i havn't heard of it. But it makes sence that 'they' have a weather band with all the wild weather over there.
\\Kaare
#38298 - 18/01/2002 18:31 Re: Tuner Specs? [Re: altman]
94cobra
Can we just enter the freq. or must the software be changed to allow this?
Sonic Blue 03 Cobra Vert Owner!!!
