#39407 - 25/09/2001 05:43 Probleme with Front Spekers
Nosferatu
Loc: France, Champagne
Recently , I bought a new Car.
Now I have a Citroen Xsara 1.4.
I Installaed my Empeg.No Problem.
But I bought new good 165mm front speakers.
They are to deep and when it's raining there water on the speakers
I protected them temporarly with plastic sheets but sound quality is (with bass, sound is bad)
Does anyone have an idea how to protect them properly ?
I'll Strike From the Grey
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#39408 - 25/09/2001 08:36 Re: Probleme with Front Spekers [Re: Nosferatu]
Derek
Loc: NRW, Germany
Factory speakers often have a stiff plastic shield that sits above them to keep the rain water off. You may be able to buy something similar. You are not going to be able to stop the water coming in.
(list 6284, Mk1 S/N 00299 4GB blue [for sale]. Mk2 S/N 080000094 26GB blue)
#39409 - 26/09/2001 09:03 Re: Probleme with Front Spekers [Re: Nosferatu]
Stereo shops sell foam backings you can mount behind the speakers. They are bowl-shaped pieces of foam. Check with a stereo installation shop for more information. These will keep the speakers dry.
Something else that is important to know:
Modern cars have what's called a "Wet door" design. The inside of the doors get wet on purpose, and drain out through holes in the bottom of the door. There is usually some kind of a plastic barrier between the upholstery and the inner side of the door. If this "vapor barrier" is cut, removed, or broken, the inside of your car will get wet.
My VW GTI had a problem where its vapor barriers came unglued after the car was several years old. I couldn't understand where the water was coming from. The floor was SOAKED, badly enough to smell moldy in the winter. I kept trying to seal holes in the floor, not realizing the water was coming in through the doors.
Finally, I read about these door barriers and popped off the door panel to discover that they had in fact come unglued and water was streaming down the inside of the door into the car.
My point is: Whenever you do any work mounting door speakers on a car, be extremely careful not to break this seal between the door and the cabin.
#39410 - 30/09/2001 23:38 Re: Probleme with Front Spekers [Re: Nosferatu]
muzza
I managed to find some tupperware type containers and cut them up to house the speaker. I fixed it on with gaff tape. as long as the top of the speaker is protected and the contacts are waterproofed, everthing is OK. Just be carefull that the mounting depth doesn't foul on the window when it winds down. I attached the shrouds, installed the speakers and then found they where 5mm too deep. after some more cutting, all was good.
Murray
Go-Wit-Da-Fro
#39411 - 01/10/2001 01:13 Re: Probleme with Front Spekers [Re: muzza]
Derek
Loc: NRW, Germany
Yep, sounds good. The other thing to watch is that the housing isn't airtight 'cause then your speaker isn't going to work nearly as well as usual. The idea is to stop water that runs down between the glass and the outer door skin from running onto your speaker. The housing can therefore be open at the bottom without any problems at all. And make sure the openning is nice and big :-)
#39412 - 01/10/2001 17:50 Re: Probleme with Front Spekers [Re: Derek]
Well, if it happened to be airtight AND properly tuned then that could be a different matter
#39413 - 01/10/2001 22:42 Re: Probleme with Front Spekers [Re: rob]
Derek
Loc: NRW, Germany
Tuned Tupperware, sounds great!
#39414 - 02/10/2001 19:21 Re: Probleme with Front Spekers [Re: Derek]
muzza
LOL
cant imagine what the hestesses of the tupperware parties would think if they saw what I did to those bowls!
Murray
Go-Wit-Da-Fro
#39415 - 04/10/2001 02:12 Re: Probleme with Front Spekers [Re: muzza]
Nosferatu
Thanks all for your help , i Will try the Tupperware Sound ................
Empeg II - 10 Gb - Red Fascia - 500 Songs -
