#5213 - 30/09/1999 11:24 1998 BMW Z3 HK System
doug316
The "upgraded" HK system in my '98 Z3 accepts speaker-inputs. It's a leased car so I do not want to replace the amp and speakers. Right now the Empeg is going straight into the amp, and I guess due to the 4V pre-outs I am actually getting good sound, just not enough volume. Anyone know of a good trick to boost the power up a bit? I was hoping I could find a cheapo little amp that I could shove behind the dash that would give me just enough juice to drive the factory amp where it should be. I don't believe there is a way to bypass the line level converter in the factory amp.
#5214 - 30/09/1999 13:01 Re: 1998 BMW Z3 HK System [Re: doug316]
n6mod
Loc: Berkeley, CA
Kenwood used to make a 7Wx2 (!) amplifier that would be perfect for this. I think I have one in the garage....somewhere. ;)
You might call Crutchfield, they seem to have lots of good solutions to these sorts of problems.
-Zandr
-Zandr
Mk.IIa #010101243 currently getting a 500GB SSD. More spares in the shed.
