#55641 - 06/01/2002 12:15 JEmplode 2.0
jwickis
Loc: India
I've been trying JEmplode 2.0 on a W98 box & having no luck in JEmplode finding my player, I'm running Emplode v2.0b7 as is the player. Is there some kind of patch I'm missing or trick? It did work at one time now it just doesn't see my player at all, I've reinstalled JEmplode 2.0 several times w/no change.
*whoops mispelled*
Edited by jwickis (06/01/2002 12:32)
#55642 - 06/01/2002 12:18 Re: JEplode 2.0 [Re: jwickis]
I've not been able to get JEmplode working with broadcast discoveries. Try specifying the empeg's IP address (press the Options button in the searching dialog) and disable the broadcast selection. Then restart JEmplode and see if it finds it.
#55643 - 06/01/2002 12:21 Re: JEplode 2.0 [Re: wfaulk]
jwickis
Loc: India
I tried that & just selecting serial connection but no luck.
#55644 - 06/01/2002 12:39 Re: JEmplode 2.0 [Re: jwickis]
AlphaWolf
I just downloaded JEmplode 2.0b1. I am running it on Mac OS X and my Empeg is connected using DHCP from my router. JEmpldoe finds my Empeg just fine. No problems here. Although I must say that I used to have problems with 2.0. What kernel are you running? I believe, if I remember, JEmplode wouldn't work with the stock 1.03 kernel properly. However it works fine using 2.0b7 developer kernel.
~Max
#55645 - 06/01/2002 14:09 Re: JEmplode 2.0 [Re: AlphaWolf]
jwickis
Loc: India
I'm running 2.0b7 dev. as well on a Win 98 box. I tried 1.03 dev w/about the same luck as I'm having w/2.0b7 dev.
#55646 - 06/01/2002 16:18 Re: JEplode 2.0 [Re: jwickis]
mschrag
Loc: Richmond, VA
Grab the latest and greatest alpha from:
http://www.batmanthehorse.com/jemplode/jemplode20.jar
I just completely rewrote discovery yesterday so it should be much more successful finding players with a broadcast. You definitely will need a 2.0 kernel on your Empeg (1.0 will be found but won't communicate). If this still does not work, run:
java -Ddebug=true -jar jemplode20.jar
and send me the output during the discovery process.
Mike ([email protected])
#55647 - 06/01/2002 18:06 Re: JEplode 2.0 [Re: mschrag]
Yep, this version finds my player on the network here at work, where the old one wouldn't. Emplode has never had a problem with it.
#55648 - 06/01/2002 22:44 Re: JEplode 2.0 [Re: mschrag]
jloew
Loc: SF Bay Area
I replaced the jar file on top of your 1/6 build and it comes up with a Fatal Application Error: InvocationTargetException. Details:
java.lang.NullPointerException
at javax.swing.ImageIcon.(ImageIcon.java:134)
at org.jempeg.empeg.emplode.action.EmplodeMenuManager.(EmplodeMenuManager.java:383)
at org.jempeg.empeg.emplode.Emplode.initGUI(Emplode.java:1119)
at org.jempeg.empeg.emplode.Emplode.(Emplode.java:192)
at org.jempeg.empeg.emplode.Main.main(Main.java:75)
at java.lang.reflect.Method.invoke(Native Method)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
MkIIa [blue]BLUE[/blue]
#55649 - 07/01/2002 05:28 Re: JEplode 2.0 [Re: jloew]
keil
Loc: Los Angeles,CA
I've got install problems as well. Tried win2000, but problems running with JRE 1.1.8 and I can't upgrade java VM...I've got other apps that need 1.1.8. So moved to debian box and got install errors below.
Linux Setup:
Debian 2.2.19
xfree86 v4
X11
java version "1.3.1"
gcc, etc...
Any advise would be great. Keil
sh ./jemplode2.bin =>
Preparing to install...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:120)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:58)
at java.awt.Window.(Window.java:186)
at java.awt.Frame.(Frame.java:315)
at java.awt.Frame.(Frame.java:262)
at com.zerog.ia.installer.Main.b(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
#55650 - 07/01/2002 09:32 Re: JEplode 2.0 [Re: jloew]
mschrag
Loc: Richmond, VA
This was my bad -- I forgot to include one of the new icons in the jar ... grab it again and it will have the fixed version.
#55651 - 07/01/2002 09:36 Re: JEplode 2.0 [Re: keil]
mschrag
Loc: Richmond, VA
I haven't done much testing with InstallAnywhere on Linux, but if this continues to give you problems, grab http://www.batmanthehorse.com/jemplode/jemplode20.jar -- it's the latest version... you can just run that
java -jar jemplode20.jar
Mike
#55652 - 07/01/2002 10:42 Re: JEplode 2.0 [Re: mschrag]
keil
Loc: Los Angeles,CA
Mike,
Thanks for the update. Will give a try.
Keil
#55653 - 07/01/2002 12:10 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
jloew
Loc: SF Bay Area
That did the trick - works great. Very slick app! I had the same problem as some others with the initial 2.0 - wouldn't find on ethernet broadcast, now it does. Whatever you did to the discovery code made a difference.
-Joe
Now, onto a new question - how to make your empeg display work? It is blank on refresh. Are there any class updates I need? I read somewhere your 1.x version required a comm update.
#55654 - 07/01/2002 12:27 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: jloew]
mschrag
Loc: Richmond, VA
If your Empeg is connected, Grab Screen should display what is on the Empeg screen in a window on your PC.
The Comm update is necessary only if you want to use serial port connectivity (to do flash upgrades).
Mike
#55655 - 07/01/2002 13:07 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
jloew
Loc: SF Bay Area
ooo, interesting. If you recall, my physical display does not work right now - totally blank, but I can interact via emplode and jemplode.
If your's isn't displaying either, does that reveal anything? How do you hook the display? Is it possible it is NOT a physical problem???
#55656 - 07/01/2002 13:40 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: jloew]
mschrag
Loc: Richmond, VA
When I "Grab Screen", whatever is on my Empeg displays in that little window. If yours is blank, something weird is definitely going on. I would talk to the Empeg folks to see if that is a physical problem or a software problem ... The fact that the protocol is returning a blank screen too is weird, though they may all be tied together.
Mike
#55657 - 07/01/2002 13:57 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
jloew
Loc: SF Bay Area
OK, sure. It made a liar out of me. Now your display works. So, it is definitely a physical problem.
Onto the next question - how to enable the polling you mentioned in an earlier email?
#55658 - 07/01/2002 14:02 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: jloew]
mschrag
Loc: Richmond, VA
ah .. That's left as an exercise for the reader Actually, if you know Java, it should be fairly easy to turn on... Otherwise, you'll have to wait for me to do another release that includes -- I may be able to add that in later tonight ....
Mike
#55659 - 07/01/2002 16:57 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
Nosferatu
Loc: France, Champagne
He mike , what about the saving of the grab display.
Will it be possible for the next release ?
The v2.0 works fine for me even the discover sequence.
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
#55660 - 07/01/2002 17:05 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: Nosferatu]
Nosferatu
Oh, I had the previous version , and yes it only discover on COM port and if I give th specific IP address of the plyer , it is find.
Nice Interface Mike.
#55661 - 07/01/2002 17:55 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: Nosferatu]
mschrag
Loc: Richmond, VA
http://www.batmanthehorse.com/jemplode/jemplode20.jar -- It supports saving .PNG format from the screen grabber now.
Mike
#55662 - 07/01/2002 17:57 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: jloew]
mschrag
Loc: Richmond, VA
http://www.batmanthehorse.com/jemplode/jemplode20.jar -- It supports starting/stopping a 1 second refresh of the screen ... I may make that speed adjustable at some point, but I just wanted to get a version out there for you ... The UI code isn't perfect, because the grabbing on/off state can get out of sync with the button, but it should be fine for now as long as you don't double-click it.
Mike
#55663 - 07/01/2002 18:06 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
From where does JEmplode actually grab the screen image?
I'm asking, because I'd like to fix things so that the Hijack menus also show up in the screen grabber. Perhaps I and/or you could make some small changes for better compatibility?
#55664 - 07/01/2002 18:22 Re: JEplode 2.0 [Re: jloew]
jwickis
Loc: India
Same here, the program won't even run at all now.
#55665 - 07/01/2002 18:36 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
jwickis
Loc: India
The program opens now whereas before I would only get an Exception Error before however my Empeg is still nowhere to be found by serial or any other means.
#55666 - 07/01/2002 20:34 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: jwickis]
mschrag
Loc: Richmond, VA
Can you run
and send me the output during network discovery?
Does RioEmplode find your Empeg?
Mike
#55667 - 07/01/2002 20:46 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mlord]
mschrag
Loc: Richmond, VA
Not sure how the Empeg stores that data... I just use the protocol's Grab Screen request, so it's pretty much a black box to me. Maybe the Empeg guys can weigh in on this one.
Mike
#55668 - 07/01/2002 21:43 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
jwickis
Loc: India
I wouldn't begin to know how to do that, Yes Rio Emplode finds them just fine.
#55669 - 07/01/2002 22:45 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: jwickis]
mschrag
Loc: Richmond, VA
If you have time, I'd like to understand this problem .. Are you running this with the JEmplode executable that came with the JEmplode installer? If so do the following:
1) open you install directory (defaults to C:\Program Files\JEmplode 2.0)
2) make sure you've replaced the jemplode20.jar in this directory with the one from http://www.batmanthehorse.com/jemplode/jemplode20.jar
3) open JEmplode.lax with a text editor (wordpad or notepad)
4) add a new line anywhere in it that says: "debug=true" (without the quotes around it -- you'll see the others that are a similar format)
5) look for two lines that say:
lax.stderr.redirect=
and
lax.stdout.redirect=
and change them to
lax.stderr.redirect=status.txt
and
lax.stdout.redirect=status.txt
6) Run JEmplode.exe
7) After discovery fails (which I assume it will based on your previous description), just quit out of JEmplode
8) Email me the file "status.txt" in your C:\Program Files\JEmplode (or whatever install directory you chose) -- my address is [email protected]
Hopefully this will contain some useful debugging information ... I'm very curious about this one. Is there anything unique about your computer or network configuration?
Thanks a lot
Mike
#55670 - 08/01/2002 18:37 Re: JEplode 2.0 - Grab Empeg Screen no work [Re: mschrag]
jwickis
Loc: India
I did as you said adding the 2 lines to .lax ran JEmplode (or tried to) & status.txt appeared in the folder but had nothing in it. When trying to run JEmplode I get this error and never get to the discovery part:
java.lang.NoClassDefFoundError: javax/swing/UIManager
at org/jempeg/empeg/emplode/Main.main
at java/lang/reflect/Method.invoke
at com/zerog/lax/LAX.launch
at com/zerog/lax/LAX.main
