#63773 - 27/01/2002 20:08 Cross compiler header problem
TheAmigo
Can someone point out what I'm missing here? I'm using mlord's pre-compiled tool-chain. I have the following program (this is the whole thing):
#include <asm/semaphore.h>
main(){}
and when I compile it, I get the following errors (these are just the first of many)
compiler error][root@linuxbox source]# gcc z.c
In file included from z.c:1:
/usr/local/armtools-empeg/lib/gcc-lib/arm-empeg-linux/2.95.3/../../../../arm-empeg-linux/include/asm/semaphore.h:17: parse error before `wait_queue_head_t'
/usr/local/armtools-empeg/lib/gcc-lib/arm-empeg-linux/2.95.3/../../../../arm-empeg-linux/include/asm/semaphore.h:17: warning: no semicolon at end of struct or union
/usr/local/armtools-empeg/lib/gcc-lib/arm-empeg-linux/2.95.3/../../../../arm-empeg-linux/include/asm/semaphore.h: In function `sema_init':
/usr/local/armtools-empeg/lib/gcc-lib/arm-empeg-linux/2.95.3/../../../../arm-empeg-linux/include/asm/semaphore.h:46: dereferencing pointer to incomplete type
(using code blocks makes the errors too long)
--The Amigo
#63774 - 27/01/2002 20:16 Re: Cross compiler header problem [Re: TheAmigo]
That would tend to mean that wait_queue_head_t wasn't defined, but it's defined in <linux/wait.h>, which is included from <asm/semaphore.h>. Odd. Maybe you can make sure that <linux/wait.h> exists and has that definition in it?
#63775 - 27/01/2002 20:55 Re: Cross compiler header problem [Re: TheAmigo]
TheAmigo
Nevermind, figured it out. I had to define __KERNEL__ for the necessary section of code to be included.
--The Amigo
#63776 - 28/01/2002 07:26 Re: Cross compiler header problem [Re: TheAmigo]
Funny.. my toolchain does NOT have a command called "gcc" in it.
Or perhaps you've added aliases/symlinks or just renamed things. If not, then you're using the wrong compiler.
#63777 - 28/01/2002 20:20 Re: Cross compiler header problem [Re: mlord]
TheAmigo
Yeah, I symlinked it because my fingers are too used to typing gcc
--The Amigo
#63778 - 28/01/2002 21:23 Re: Cross compiler header problem [Re: TheAmigo]
Okay. Just be careful that this isn't the source of your woes..
When building binaries like this, I sometimes create symlinks for EVERYTHING in the ?????/bin directory, and dump it at the head of the PATH.
#63779 - 29/01/2002 17:48 Re: Cross compiler header problem [Re: mlord]
TheAmigo
Yep, I made symlinks for all of 'em. I have an alias called "empeg" that prepends the armtools bin dir to my path. I have another alias called "tivo" that prepends my ppc toolchain's bin dir to my path. Having them as aliases, by default "gcc" runs my native compiler.
Right now, what I'm interested in doing is setting up a working IrCOMM connection to the empeg. I've got IrCOMM set up on my Win98 box through an external IR dongle. I can run a terminal program to COM4 (the virtual com port provided by my Windows IrCOMM driver) and point the dongle at the empeg (currently about 4 inches away). But I still have some work to do on the empeg side. Do you have IrCOMM support already compiled into hijack or do I need to compile my own modules and load them? I noticed that I don't have a /proc/modules so I can't tell what modules are loaded.
--The Amigo
#63780 - 29/01/2002 19:18 Re: Cross compiler header problem [Re: TheAmigo]
No irda in hijack.
No modules support in the kernel.
