#64620 - 30/01/2002 07:22 Starts with no visuals in home and car
tms13
Loc: Lochcarron and Edinburgh
I know that the player is supposed to start up in a full-screen-info mode, in the car. But it also does so when I use it on AC at work. And in the car, I need two long presses of the bottom button to toggle into visual mode (just one at work, though).
Version 2.0b7 - I think it was okay in 2.0b3.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#64621 - 30/01/2002 11:16 Re: Starts with no visuals in home and car [Re: tms13]
prolux
Loc: Manchester, UK
Have you tried setting the info mode through the menu, or via the remote control.
The way it works is that two info modes are persisted per channel, one last full screen one selected, and the last non-full screen one selected. Holding the bottom button will toggle these two modes.
Try selecting your favourite full screen info mode through the menu, then selecting your favourite non-fullscreen info mode through the menu. Once you have done this, providing you don't cycle through again with the remote (this issue may be addresed in a future release) you should find that holding the bottom button toggles correctly.
Let me know if it doesn't
Toby.
#64622 - 30/01/2002 12:17 Re: Starts with no visuals in home and car [Re: prolux]
tms13
Have you tried setting the info mode through the menu, or via the remote control?
Probably both - and also by toggling using the Down button.
I've just had a play here in the office - it does remember correctly whether or not it was on a full-screen info if it was selected by menu, but not if it was subsequently changed by the remote or by toggling before power-down. And of course, in the car, I'm likely to start up, toggle the info off, then do nothing till power-down if it's a short journey.
I'll have more of a play (in the car) and see what happens.
Thanks for the workaround.
Toby Speight
#64623 - 01/02/2002 05:04 Re: Starts with no visuals in home and car [Re: tms13]
I too need 2 long presses of the down key in the car, but at home it starts in whatever state I left it last time it was turned off at home.
Not sure why it needs 2 presses in the car - I was under the impression one would do.
#64624 - 01/02/2002 08:47 Re: Starts with no visuals in home and car [Re: frog51]
tms13
I found that Toby was right about it working correctly only when Info is chosen from the menu (not remote or by toggling), in the car as well as on AC.
Toby Speight
#64625 - 02/02/2002 07:28 Re: Starts with no visuals in home and car [Re: tms13]
justinlarsen
Loc: Petaluma, CA
try running hijack, and use the restore visual option..
---- Justin Larsen
