#67811 - 06/02/2002 13:18 Ports in config.ini
jheathco
Loc: Mission Viejo, California
How do you specify an ftp/http port in the config.ini.... I couldn't find it on the empeg-hijack sourceforge site.
John Heathco - 30gig MKIIa w/ tuner module
#67812 - 06/02/2002 13:36 Re: Ports in config.ini [Re: jheathco]
tarkie
From the patches to the default kernel:
kftpd_control_port - defaults to 21
kftpd_data_port - defaults to 20
khttpd_port - defaults to 80
Enjoy
M2a/Smoke/60gb/Tuner!! Thanks Joe M2a/Blue10gb Thanks Ian!
#67813 - 06/02/2002 13:49 Re: Ports in config.ini [Re: tarkie]
jheathco
Can't seem to get the khttpd_port to work... keeps on staying on 80
#67814 - 06/02/2002 14:24 Re: Ports in config.ini [Re: jheathco]
tarkie
Which release of HiJack are you running as it was broken a while back.
#67815 - 06/02/2002 14:33 Re: Ports in config.ini [Re: tarkie]
jheathco
The latest, I have all my hijack settings under [hijack]... should they be somewhere else for http?
#67816 - 08/02/2002 08:24 Re: Ports in config.ini [Re: jheathco]
They all go under [hijack].
If you upgrade to the latest Hijack, say v190 or so, then hijack will pop-up an error message on the display if things are not right, just after the boot-up animations.
But take a close look at your config.ini first, if it has any garbage characters in it, those may prevent it from being parsed correctly.
