#7106 - 10/05/2000 04:57 powered antennas
Liufeng
Loc: Alaska
Ok I know this may be only a concern to like five people, but... with my SAAB headunit the powered antenna doesn't extend unless the tuner is selected. You can play a CD or cassette and the antenna will stay down and I think that is really nifty. Will the mark 2's have a way to leave the powered retractable antenna down during mp3 play???
Reg_2845 Serial #00173
Reg #2845: Mark 1 #00173, Mark 2 #119, Mark 2a
#7107 - 10/05/2000 13:50 Re: powered antennas [Re: Liufeng]
eternalsun
Loc: San Jose, CA
That's a cool idea!
Calvin
#7108 - 11/05/2000 18:47 Re: powered antennas [Re: eternalsun]
Alexander
Loc: SF Bay Area
My 2001 Mitsubishi Eclipse Spyder does this too. I have no idea how it's controlled, or, for that matter, how I'm going to install my Empeg. (There's physical space for it below the factory unit, but I don't know how the wiring will turn out...)
Alex
#7109 - 11/05/2000 19:15 Re: powered antennas [Re: Alexander]
BillB
Loc: Orlando, FL USA
A lot of aftermarket head units (and presumably any factory unit that's used on cars with power antennas) have a power antenna wire, that works basically like an amp remote turn-on wire, but instead of turning on with the head unit, it turns on with the tuner.
I don't remember anything mentioning the Empeg having a power antenna lead. Your best alternative might be to wire up a conveniently located switch that will allow you to raise and lower your antenna at will. Yes, it's an extra step, but it's probably more aesthetically pleasing than leaving your antenna up all the time.
Bill
[orange]Bill B.
Mk.2 SN 080000183 - 38 GB /[/orange] [green] Green [/green]
#7110 - 13/05/2000 02:31 Re: powered antennas [Re: BillB]
jbauer
Loc: San Francisco, CA
Hm. Wow, I was hoping that the Empeg had a lead for this...
Are we SURE that the Mark II will NOT have this?
I installed a power antenna in my Miata because I hated that the antenna was up all of the time. I DON'T want it to stay up if I'm not using the tuner...
- Jon
#7111 - 13/05/2000 03:44 Re: powered antennas [Re: jbauer]
The tuner module isn't finalised yet; I'll see what can be done ;)
#7112 - 14/05/2000 01:44 Re: powered antennas [Re: altman]
jbauer
Hugo, THANK YOU, THANK YOU, THANK YOU...
Please make it happen! I love my power antenna!!!
- Thanx again!
- Jon
#7113 - 16/05/2000 04:34 Re: powered antennas [Re: Liufeng]
One wish list feature this may impair is the ability to be alerted to traffic announcements when MP3's are playing.
Just figured I'd drop that in, since thats one thing I will definitly want if I end up moving to LA anytime soon.
#7114 - 17/05/2000 18:49 Re: powered antennas [Re: Liufeng]
Anonymous
Unregistered
Curently the EMPEG has a allways on lead that can be used as a remote for either a amp or to control the antena power booster suplied with the EMPEG, or if you like can also be used to triger the power antena. But as this is a always on lead (only on when the empeg is on though), the antena will extand even in MP3 mode.
As to the trafic / news service via the RDS system, any system should be able to pick these up with the power booster, even if the arial is down, so as soon as news signal is recieved, it could still be triggered. I reciently tested somthing simalar to this, my friends ALPINE system had no power booster but with a audio quality of about 4 out of ten with the arial down, it was still able to pickup and recieve the news signal and extend the areial to give a 10 out of 10 audio quality.
#7115 - 14/07/2000 01:27 Re: powered antennas [Re: altman]
jbauer
Any news yet on this front???
- Thanx
- Jon
#7116 - 14/07/2000 02:48 Re: powered antennas [Re: jbauer]
Not yet, no. The tuner is likely to be a bit late, we've had our hands full keeping the mk2 production moving! We've got a working prototype, it just needs to be finished off for production. Hopefully there shouldn't be any problems with this, as it's a pretty simple board.
#7117 - 14/07/2000 03:07 Re: powered antennas [Re: altman]
teemcbee
So is there a chance for the rest of the 1000-patch to come with tuner already? Or will it come later?
How are things going on with the rest of ..?
TeeMcBee
TeeMcBee
#7118 - 14/07/2000 06:05 Re: powered antennas [Re: teemcbee]
No, the tuner will come later for everyone in the first 1000 probably. Sorry, it's been hectic!
