#74515 - 24/02/2002 12:07 Clock Display
gberlant
Can someone program it so I can have a time display that is on the screen. I like to have info on when I play my songs, so if the clock could go in the lower left or something, that would be great. If this already exists, how do you do it.
Thanks,
Greg
#74516 - 24/02/2002 12:29 Re: Clock Display [Re: gberlant]
Use version 2.0 of the software and press the 1 key on the remote control to select the desired time format. One of the time formats is "Clock".
#74517 - 24/02/2002 17:05 Re: Clock Display [Re: tfabris]
gberlant
Is it possible to have the clock display while I have the info for the track on?
#74518 - 24/02/2002 17:11 Re: Clock Display [Re: gberlant]
Use version 2.0 of the software and press the 1 key on the remote control to select the desired time format. One of the time formats is "Clock."
It doesn't any simpler to explain. And I don't think anyone's going to draw a picture.
#74519 - 24/02/2002 17:14 Re: Clock Display [Re: gberlant]
Yes, Info:Track is one of the displays where the clock can be made visible. You can see the track information at the same time as you see the clock. Again, this requires version 2.0 of the software.
If you mean that you want the TIME COUNTER for the track visible at the same time as the clock, then no. But that's not what you asked, you asked about the track info.
