#77873 - 05/03/2002 12:09 Slow movement through songs with beta 2.11
mo3211
Loc: Miami, FL United States
I don't know if its just me, but I have noticed that pressing the "next song" button to move through songs in a playlist and holding that button, the movement from song to song goes much slower than it did in the prior software releases. I used to be able to fly through my playlist, now it flies through 3 songs, then slows down, then speeds up, but in total, its much slower than before.
MKII 12GB MKII 30GB
#77874 - 05/03/2002 14:41 Re: Slow movement through songs with beta 2.11 [Re: mo3211]
I think that "holding the button" activates "Fast Forward" within the current track, not "move quickly" through playlist.
EDIT: or did you really mean "when navigating under the playlist submenus" ?
Edited by mlord (05/03/2002 14:42)
#77875 - 06/03/2002 13:58 Re: Slow movement through songs with beta 2.11 [Re: mlord]
mo3211
I mean when you select an entire playlist to play. There is a set of buttons that allows you to fast forward and rewind through a song and there is a set of buttons that allows you to go to the next or previous song. I used to be able to press the "next song" button repeatedly to go through songs, or just keep it pressed to go through the songs very quickly. Now if I leave it pressed it goes through the songs, but slowly. I have the empeg remote control, I don't know how different it functions compared to the rio remote control.
MKII 12GB MKII 30GB
#77876 - 06/03/2002 15:04 Re: Slow movement through songs with beta 2.11 [Re: mo3211]
There's no such thing as an "empeg remote". Did you mean, the "kenwood KCA-R6A remote" ??
#77877 - 06/03/2002 15:07 Re: Slow movement through songs with beta 2.11 [Re: mlord]
If you did mean "Kenwood remote", I also have one here, and just verified the same behaviour. But this is with a Hijack kernel.
Perhaps behavior is different without Hijack installed? That's actually quite possible for those two buttons, but I'm not 100% sure if that is the case here.
#77878 - 07/03/2002 08:11 Re: Slow movement through songs with beta 2.11 [Re: mlord]
mo3211
Yes, I meant the Kenwood remote. I've read about kernels but have not been able to research them to know exactly what they are-- although I believe they have something to do with the programming language used in linux used to run the player. I was starting to think the slow movement might of just been my imagination, but I'm glad to see you experienced a similar effect and it wasn't just me. Thanks for your assistance in confirming this.
MKII 12GB MKII 30GB
#77879 - 07/03/2002 09:20 Re: Slow movement through songs with beta 2.11 [Re: mo3211]
mo3211
I did a little research and have learned what the kernel is. I have not installed the hijack kernel in my player, so I really don't think its the hijack kernel which causes the inconsistent speed of moving through songs. By the way mlord, now that I have done some research, and realize who you are and have checked out your Hijack web page, I have to say thanks for your work with linux and for your time in creating such a great add-on for the empeg and I can't wait to install it in my player this weekend.
MKII 12GB MKII 30GB
#77880 - 07/03/2002 09:28 Re: Slow movement through songs with beta 2.11 [Re: mo3211]
Oh good, then it's not a side effect of Hijack. Nice to know that!
Adding Hijack to your player takes only a couple of minutes, mostly while waiting for the slow serial data transfer to complete. You'll be pleased with both the process and the outcome.
#77881 - 07/03/2002 10:45 Re: Slow movement through songs with beta 2.11 [Re: mo3211]
Does the behavior of your Kenwood remote, when running the version 2.0 beta 11 player firmware, behave correctly according to this guide?
Note: I do not have the "Info: Seek Tool" behaviors entered into that button guide yet. The behaviors in that guide should only count for the screens other than "Info: Seek Tool".
#77882 - 07/03/2002 11:08 Re: Slow movement through songs with beta 2.11 [Re: tfabris]
Yeah, works fine. Just the auto-repeat on "next/prev track" is very slow.
#77883 - 09/03/2002 11:54 Re: Slow movement through songs with beta 2.11 [Re: tfabris]
mo3211
Yes, my remote control functions as described in that guide.
MKII 12GB MKII 30GB
