#82878 - 21/03/2002 21:27 Identifying a mark2a?
shadow45
Loc: Florida, USA
I just got an Empeg from carplayer.com, and just finished installing it. It's great so far, exactly what i've dreamed of for the past 2+ years.. my question however, is how can I identify this as a mark 2a or 2? I was told by the carplayer people it's a 2a, but I'm getting the audible pop when I turn off the car(negative spike bug) and the FAQ tells me the 2a has the diode to silence this built in.
What gives? did I get duped? *sigh*
::: shadow45
#82879 - 21/03/2002 21:31 Re: Identifying a mark2a? [Re: shadow45]
robricc
Mk2a says Rio on the top cover above the vent.
#82880 - 21/03/2002 21:32 Re: Identifying a mark2a? [Re: shadow45]
The 2a will have Rio printed on the case, the 2 will have Empeg printed on the case.
Remember that the negative spike bug is only one common reason for the pop. Other reasons are related to bad/incorrect wiring or cheap equipment. The FAQ does mention this, too.
#82881 - 21/03/2002 21:45 Re: Identifying a mark2a? [Re: tfabris]
shadow45
Loc: Florida, USA
Hmm, I wouldn't even know where to begin. So i shouldn't bother with the diode since the 2a already has this? I've got a Kicker amp, and I bought the Empeg to replace my old Clarion head unit that finally took a dump 2 weeks ago.. I never had this problem with the Clarion. The FAQ says it could also be fuses, I guess I will check all my fuses out. Damn, it's like a needle in a haystack! Thanks for the help..
in the meantime, is this pop causing damage to my setup at all? Sounds like it could..
::: shadow45
#82882 - 21/03/2002 21:59 Re: Identifying a mark2a? [Re: shadow45]
robricc
If you take the empeg out before cutting the ignition do you still get the pop?
FWIW I had the pop on my Mk2 for two months before correcting it. Nothing was damaged.
#82883 - 22/03/2002 08:47 Re: Identifying a mark2a? [Re: shadow45]
Derek
Loc: NRW, Germany
If you have a 2a adding a diode isn't going to make any difference. There are other things that could make it pop, like not having a permanent 12V supply, or having the permanent and switched 12V lines round the wrong way (if I remeber rightly)
#82884 - 22/03/2002 13:38 Re: Identifying a mark2a? [Re: robricc]
shadow45
Loc: Florida, USA
If i turn off the empeg before killing the ignition, i don't hear the pop. that leads me to think it's something having to do with my installation, although i am certain i wired it correctly. i will check that out tonight as soon as i get home (and my cable modem gets installed! gah, about time)
thanks for your help
::: shadow45
