Allow Dr. Brad to help.... first of all, you need to realize that you and Girlfriend 1.0 are not working off of the same operating system. If you are into connecting into platforms running the same OS, then there is nothing wrong with that, but from your post, I am guessing that is not your situation. Now, there are certain bi or "dual OS" platforms out there, and while they open up a world of possibilties (and can be quite fun) they are not very stable or secure. So, I recommend keeping your GF 1.0 and simply implement a few tools to help you co-exist.
Luckily, you and GF 1.0 are very compatible. You simply use differant sytax. For instance, do not refer to Mark Lord's hack as "HiJack." Instead, use any of the following GF 1.0 compatible terms (builds): "Ravish v253", "Seduce v253" or "SweepMeOffMyFeet v253".
Another tip would be to use the attached .raw file in place of your "logo.raw" in your visuals folder. Fire up TuxTooMuch and some of GF 1.0's favorite music and you will be all set. The finishing touch would be to create an image pan with an image of GF 1.0. Then, your migration will be complete.
83675-logo.raw (197 downloads)
