#94208 - 16/05/2002 07:47 Help, Empeg only playing out of left speaker
LaneStar
Loc: Portland Or, U.S.A.
Yesterday my empeg just decided to play out of one speaker. i changed rca's, and then changed the reciever I was playing it through. (at home, never had it in my car) I rebooted a few times. Nothing worked. Anyone had this prob B4? Help!!!! -LaneStar-
MKIIa 30gb in a 1998 Cadillac Catera
#94209 - 16/05/2002 07:54 Re: Help, Empeg only playing out of left speaker [Re: LaneStar]
David
Loc: Cambridge
Check the EQ and balance settings. Try the car outputs as well. If just the home output is affected, you may have a broken track by the RCA jack.
#94210 - 16/05/2002 07:59 Re: Help, Empeg only playing out of left speaker [Re: David]
LaneStar
checked the eq, and balence. Still nothing. This empeg has never been instaled in a car yet, so it only has been used at home. -LaneStar-
#94211 - 16/05/2002 09:15 Re: Help, Empeg only playing out of left speaker [Re: LaneStar]
David
Loc: Cambridge
Put the player in the sled and connect the power through the hole in the rear of the sled.
You can then test the car outputs - the player doesn't need to think that it is on car power.
