You can install pcAnywhere 10.5 remotely (no need to use TS) and no reboot is required. pcAnywhere 10.5 also does not use a custom GINA. Many other remote control packages are available.
It is also possible to perform a remote installation of SQL 2000 as part of the normal Microsoft installation, or failing that you can configure an unattended installation and kick that off remotely.
