In the Bios, don't let it auto detect the drive type. TELL it that the drive is a particular size. you MUST have it in the correct MODE too, most prbably in LBA mode.
The BIOS is probably giving the CHS setting in normal mode. THIS WILL NOT WORK. even in AUTO, tell it that you want to use LBA.
Murray
I What part of 'no' don't you understand?
Is it the 'N', or the 'Zero'?
