I believe it is just that. A spot weld. The tip on the spot welder is usually not spotlessly clean. As a result, there is a certain amount of discoloration when the impurities on the spot welder tip burn in contact with the metal to be welded.
BTW: Mine has the same mark, only darker.
'a stock car stereo is a beautiful thing to waste' MKIIa 60gb MKIIa 20gb
