If you get an IEC brick power supply with a separate lead, it will work with a UK supply using an ordinary kettle lead to replace the US lead.
If you get the US all-in-one supply that has the plug built-in, it's 120V only and you'll need to spend a tenner or so on a UK supply.
Does that make things clear?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
