Hi!
I was wondering if any of you guys out there have a good solution to broadcasting the empeg on the internet even if the empeg has a local ip adress?
The way my system is working now is that I have a gateway thats on a dynamic ip. And I have my empeg connected to it through my LAN. What I want is to broadcast the empeg webserver to the internet.
That could be fairly easy just to add a hub in front of the gateway and hook the empeg up to the WAN. But I want to use services like dns2go to point to the empeg.
My gateway is a win2k machine btw. And I installed apache on it and tried to point it directly to the empeg. This is kinda a longshot but i just had to try. ofcourse it didnt work.
I was thinking that i could install samba on the empeg and then mount the empeg as a drive in 2k. And then point the webserver to the virtual drive. But then i had some problems on installing samba. As i dont currently have a linux system to compile the samba source. Didnt find any binaries on any arm disps. My linux capabilities are pretty rudimentary so i would appreciate a VERY easy how to do explenation.
Is there an easier way to make this work?
