edsmiata: What year Miata do you have?
A 1996 M-Edition. I haven't found a good amp for it yet, though, so it isn't installed. What amp did you use and where did you install it? My problem is that I want a stealth install, where the amp is not in the trunk. At the same time the amp needs to be big enough to power the ten speakers I have in the little thing.
32MB, serial: 10101626
