There probably is a bit of order dependence .. I need to try out some scenarios, but I suspect if you put the search first, it will prefilter the nodes and they won't trickle down to the by Artist. On the flip side, if you do By Artist first, you may end up with empty artist name playlists since it might create the artist playlist then decide not to put anything in it .... It probably _shouldn't_ be order dependent, but I'm too stupid right now to work through that one ... I'll try it out.
ms
