had it happen to a few different songs, but if I rewind it's OK
If I remember correctly I noticed this first in release 10A. When on a few longer trips it appeared that the error happened at the very same spot in a lengthy playlist same track; same place) if the playlist was left alone running from the very beginning. Playing with the sequence of the playlist prior to the track in error seemed to prevent (postpone??) the error. Also there as nothing wrong with the track itself: playing it by itslef, in another (shorter) playlist made it run smoothly.
I bet it is in the software. A buffer underrun; some clean-up action; or something similar.
Haven't had a chance to play with it since: sold Emma shortly thereafter and don't have sufficient tracks on Mark2 yet to play with the assumption again.
Henno
mk2 nr 6
Henno
mk2 [orange]6 [/orange]nr 6
