Did you actually get it to work after transplanting the platters? You could do this years ago when the platters had a fairly low bit density but these days the tolerance needed is way too high for somebody to do it at home.
SMART monitoring hasn't worked very well for me. It only started warning me once there was serious problems with the drive which were noticeable anyway.
- Trevor
