It would be right that the errors don't show up immediately, but only after a while of use.
Imagine only one dust particle being trapped in the once opened harddisk. Surely that one little particle won't cause very much damage in the first ten seconds when you use your drive again. But it will grind on the platters every day, causing a little bit more damage and, given due time, data errors will show.
