The pattern in the top is suitable for mounting a small fan (low profile 40mm I think), though you will void your warranty doing this. The "motherboard" is the whole bottom of the case.
Actually, most heat comes from the display, which has a filament heater - this them gets dissipated in the metalwork. The actual main board generates very little heat, it's all in the display/drives.
Hugo
