I Was actually going to punch a hole in the air system after the aircon but before the heating so that the emepg has cold air ALL the time. I have noticed problems when it overheats.
it would be a simple matter of siliconing a tube into the airway then having it attached onto the sled so that it sprays onto the top holes. Alternatively, a hole could be drilled in either side of the sled to pump air in the side vents. wouldnt have to be much.
Murray 06000047
____________________
Murray
I What part of 'no' don't you understand?
Is it the 'N', or the 'Zero'?
