I cant get my converter program to convert from .bmp to bin. Does the logo file have to be 2.1 k? Or can it be different. If it does, then how do i make it exactly that size?
It has to be that size. Make sure it's color-reduced to a palletized format, for instance, 16 colors. Make sure it's 128x32. Actually, my FAQ says that you can use MS Paint, but now that I think about it, that program might not work and you could be forced to use another piece of software. Has anyone successfully used MS-Paint to make one?
If you haven't read my entry in the FAQ, check it out and see if it helps.
___________
